SFTP/SSH/SCP file transfer to/from 3560 switch
Jul 30th, 2010
I am trying to transfer files to
3560 switch using one of the above protocols.  I can connect to the switch via ssh
successfully for day to day mgmt.  however when I run
WinSCP of filezilla I am
unable to establish a connection.  I can authenticate successfuly but than receive the following error.
"Cannot initialize SFTP protocol. Is the host running a SFTP server"
As far as I can tell this should be possible or am I missing something?  Thank you
debug and partial config below
authentication successful for cisco
00:28:25: SSH2 0: ssh_receive: 68 bytes received
00:28:25: SSH2 0: input: packet len 48
00:28:25: SSH2 0: partial packet 16, need 32, maclen 20
00:28:25: SSH2 0: MAC #7 ok
00:28:25: SSH2 0: input: padlen 19
00:28:25: SSH2 0: received packet type 90
00:28:25: SSH2 0: channel open request
00:28:25: SSH2 0: send: len 32 (includes padlen 10)
00:28:25: SSH2 0: done calc MAC out #7
00:28:25: SSH2 0: ssh_receive: 84 bytes received
00:28:25: SSH2 0: input: packet len 64
00:28:25: SSH2 0: partial packet 16, need 48, maclen 20
00:28:25: SSH2 0: MAC #8 ok
00:28:25: SSH2 0: input: padlen 15
00:28:25: SSH2 0: received packet type 98
00:28:25: SSH2 0: simple@putty.projects.tartarus.org request
00:28:25: SSH2 0: MAC #9 ok
00:28:25: SSH2 0: input: padlen 16
00:28:25: SSH2 0: send: len 16 (includes padlen 6)
00:28:25: SSH2 0: done calc MAC out #8
00:28:25: SSH2 0: subsystem request
00:28:25: SSH2 0: subsystem message received
00:28:25: SSH2 0: searching for subsystem sftp for vty
00:28:25: SSH2 0: send: len 48 (includes padlen 18)
00:28:25: SSH2 0: done calc MAC out #9
00:28:25: SSH2 0: done calc MAC out #10
00:28:25: SSH2 0: done calc MAC out #11
00:28:25: SSH2 0: done calc MAC out #12
00:28:25: SSH0: Session terminated normally
Configuration
username cisco password 0 cisco
aaa new-model
ip domain-name cisco.com
ip ssh version 2line vty 0 4
exec-timeout 0 0
password cisco
transport input all
transport output all
line vty 5 15
exec-timeout 0 0
password cisco
transport input all
ip scp server enable
Siddharth Chand... Fri, 07/30/2010 - 13:58
3560 switches do not support SFTP. WinSCP uses SFTP by default for connections. Hence the error.
3560 switches do support TFTP/FTP for the above, so use a TFTP/FTP server instead.
Sid Chandrachud
TAC-Customer Support Engineer.
