ASA 5505 is not boot up
aminulnt
My ASA5505 is not boot up. I did upload ios from rommon mode with tftp and tftpdnld.It is uploaded successfully after reboot it stopped at cisco logo sing.
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
I deleted old ios and upload new but look same. Can any one give any suggestion?
16 Replies 16
Magnus Mortensen
     Was a recent hardware change done (Memory Upgrade)? Can you please post the full boot up sequence from the time you plug in power, to the point at which it hangs.
- Magnus
Thanks for your reply. Yes we did but same thing before and after. I attached boot sequence. Would be appreciated let me know your views.
Aminul
Aminul,
     The attached zip only has a text file with:
Copyright (c) 1996-2010 by Cisco Systems, Inc.
                Restricted Rights Legend
                Cisco Systems, Inc.
If you attach a console cable and then plug in the ASA you shoudl see something start like....
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)6 08/21/06 17:26:53.43
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)6) #0: Mon Aug 21 19:34:06 PDT 2006
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Launching BootLoader...
Please send the full boot up output.
- Magnus
Thank for your prompt reply .Yes you are right. It is text file. Now I am in home. I will do it from my office. I am really appreciating your feedback.
Aminul
As per your suggestion I upload ios form rommon it stacked on
                   Cisco Systems, Inc.
After that when I power off and on it showing message which I attached.Would be appreciated if you let me know your views.
Aminul,
     It looks like the flash is corrupted on that firewall. As a result we must format the flash. Please do the following:
1) Boot from TFTP again so that you can get to the ASA prompt
2) Format the flash with the command 'format flash:'
3) Copy the image from TFTP to flash:
Worth noting is that the Rommon TFTP boot *does not* copy the code to flash. You must copy it once again once the firewall has booted and you can access the prompt.
- Magnus
Hi Magnus
Thanks for your reply. Actually I am unable to go privilege mode .My asa stacked before going to privilege mode. Is there any way to format the flash from rommon mode or what is your suggestion? Would be appreciated if you let me know your views.
Aminul
Aminul,
     I see you are trying to boot up 7.2.2. What does the boot up sequence look like if you try a later build like 7.2.5 or 8.2.2 (which can be downloaded from cisco.com).
- Magnus
Hi Magnus
Thanks for your reply. Yes I did 7.2.2 and also try to 7.2.5 which I downloaded from Cisco. Any information would highly appreciate.
Aminul
Aminul,
     Can you post the 7.2.5 output. There were some code changes with flash handling between 7.2.2 and 7.2.5 and it may display different output that could help track the issue further. Also please try 8.2.2 if you can, there were plenty of changes that went in in how the firewall code interacts with the HW. In the end, if the flash is unrecoverable, you would need to RMA it which would involve you openning a service request. So lets try 8.2.2, if it is the same result go ahead an open a service request since we may just be chasing a HW issue this whole time.
- Magnus
Hi Magnus
Thanks for your reply. I upload new software 8.2.2 but still same thing. Please have a look attachment for output. Any information would be appreciated.
Aminul
sbjones13
Was this issue ever resolved. I have the same problem.
waple02
  I have thesame problem with ASA 5505 stop loading the IOS. The stack to this stage. I cant install new ios the port is dead also i cannot any of the ports assigned on the firewalll. Any one help me
Cisco Systems, Inc.
I am also having this issue. Did anyone resolve this problem?
