Nagaraja Thanthry Sat, 07/31/2010 - 09:35
  • Cisco Employee,
There is no specific tool that tells you which IOS to use for different security vulnerabilities. However, if you go through Cisco's vulnerability documents, they specify the IOS where it has been addressed (the document specifies the first IOS where it is fixed). So, you can pick any IOS (in that train) that is released after the release of the first fixed IOS.
Hope this helps.
NT
Ganesh Hariharan Sat, 07/31/2010 - 10:46
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Is any cisco tool available to find the IOS remmendation for Secuirty Vulnerablities ?
Mathew
Hi Mathew,
As told by NT i dont think ios tool is there for security vulnerabilties for cisco ios,check out the below link for security vulnerabilties for cisco.
http://www.cisco.com/en/US/products/products_security_advisory09186a0080b20ee5.shtml
http://www.ciscozine.com/2010/03/30/march-2010-seven-more-new-cisco-vulnerabilities/
Hope to Help !!
Ganesh.H
