configuring SIP Trunk between Callmanager and Th3d Sip Gateway
Jul 31st, 2010
I have the following problem:
I don't understand how I have to configure my callmanager 7.1.2 to comunicate and to register with a th3d Sip gateway.
The main problem is that th3d Sip gateway to have to register with my callmanager with username and password.
how I have to configure the callmanager and which are the configuration menu that I have to set up ?
Thanks a lot
Best regards
Steven Holl Tue, 08/17/2010 - 08:22
If a DN registration is required by the Th3d SIP gateway, then you need to place a SIP-to-SIP CUBE between CM and Th3d.  CM doesn't support SIP registration, but CUBE does under the sip-ua configuration.
