telnet not allowed
suthomas1
Level 6
Level 6
From my VPN segment, i try to access this another asa firewall of mine and it gives following error:
TCP access denied by ACL from 10.27.200.20/3268 to Inside:10.45.114.4/23
10.27.200.20 is my vpn ip , 10.45.114.4 is inside interface of my another asa firewall ( which is being tried to access ).
capture results on destination asa firewall on inside shows:
00:34:22.072033 10.45.114.4.23 > 10.27.200.20.3203: R 0:0(0) ack 1912878303 win 65535
   2: 00:34:22.632459 10.45.114.4.23 > 10.27.200.20.3203: R 0:0(0) ack 3856471911 win 65535
and
1: 00:29:28.556367 10.27.200.20.3114 > 10.45.114.4.23: S 689313684:689313684(0) win 65535 <mss 1366,nop,nop,sackOK>
   2: 00:29:29.736457 10.27.200.20.3114 > 10.45.114.4.23: S 3857537545:3857537545(0) win 65535 <mss 1366,nop,nop,sackOK>
   3: 00:30:04.756293 10.27.200.20.3124 > 10.45.114.4.23: S 1620863463:1620863463(0) win 65535 <mss 1366,nop,nop,sackOK>
as per the acl denied message, acl was put to allow telnet but it gained nothing.
Appreciate inputs to resolve this!
Great thanks.
hi
as NT suggested telnet will work only on highest security level or inside
secondly can you please paste the relevant telnet configuration
show run | in telnet
also can you ping the interface that you are trying to telnet
Nagaraja Thanthry
Try issuing "management-access inside" command on the remote firewall.
Hope this helps.
NT
Thanks , tried but that doesnt help.
How exactly the ASA where VPN is getting terminated and the other ASA (one
you are trying access) are connected? Are they connected with their inside
interfaces on the same subnet or is it that the inside interface of VPN
terminating firewall is connected to outside interface of the other ASA? If
you are trying to access the ASA through its outside interface, then it may
not work.
NT
hi
