Jul 31st, 2010
Does anyone know the OIDs for the SA520?  I am specifically looking for the CPU and memory OIDs to use in my SNMP software.
I have loaded all the MIBs as listed on the SA help pages from Cisco. I even found the OID [] for the CPU. That OID does not appear in the MIBs recommended by Cisco but does CISCO-MIB on my management software. However, the OID returns a NULL response from the SA520.
Any ideas?
hyeh Sun, 08/01/2010 - 01:16
Hi Clark
All the SA500 supported MIBs are listed in
The represents "5 minute exponentially-decayed moving
average of the CPU busy percentage" is not there yet. We have the following DDTS to track this issue
   CSCtb53251-Memory Pool & Process MIBs are not supported on SA 500 series devices
We don't have the date when this enhancement will be included in the firmware.
If you just want to locate your SA520, you may define your own system name and location
by changing "SysName" and "sysLocation" in SNMP System Info page if needed.
clarkboyd Sun, 08/01/2010 - 03:51
I have SNMP configured correctly and am receiving traps. I also have all the recommended MIBs downloaded and installed.
I am trying to see what information I *CAN* monitor such as those shown on the RESOURCE UTILIZATION section under the STATUS tab.   It seems to be rather limited on the SA520.
