lms3.2 and wcs
dorkiayang
Sir:
I want to install LMS3.2 and WCS in one server,but coundn't install both.
Can I do so?
5 Replies 5
Sven Hruza
Level 4
Level 4
I searched for the informations in the docu, but I can't find it.
But I think that it is not supported to install any other software on the same server with LMS or WCS.
Sven
I see
Thank you!
I stop the LMS’s service then can install the WCS,
But when I started the LMS's service, the WCS cann't be started.
infor:
Starting WCS
The Cisco Wireless Control System (4.2.62.11) service is starting...
The Cisco Wireless Control System (4.2.62.11) service could not be started.
A system error has occurred.
System error 1067 has occurred.
The process terminated unexpectedly.
Failed to start WCS server.
The first problem could be, that you will have a web server and a TFTP on LMS and the same on WCS.
Here you will find an info about used ports from WCS:
http://www.cisco.com/en/US/products/ps6305/products_qanda_item09186a00807a60f0.shtml
And here you will find the ports LMS uses:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html
Sven
Thank you!
No way. I will install WCS in another server.
Yes, that would be the best and only way to get the system running and support from Cisco.
Points are welcome
Sven
