07-31-2010 11:58 PM - edited 03-16-2019 12:01 AM
Hi all,
My scenario is CUCM 7 and a VG224. I'm trying to configure a emercency service but it's not working only with the analog with the analog phones connected to the VG224.
There is a translation thats when the user dial *5555 the call should call a PSTN number. The IP Phones uses the same CSS of the Analog extenions but this translation is not working on the VG extensions. When I try to call *5555 on the analog extension it's get a message the this number cannot be dialed after the *55.
I'm think there is a standard supplementary service to use *55 to call a speed dial but i dind't find any way to change that.
Anybody have any ideia of how to fix this issue?
Any help will be appreciated.
Solved! Go to Solution.
08-01-2010 06:39 AM
Hi Guilherme,
You can change the * - Prefix for Speeddial to #;
1. enable
2. configure terminal
3. stcapp feature speed-dial
4. digit number
5. prefix prefix-string
6. speed dial from digit to digit
7. redial keypad-character
8. voicemail keypad-character
9. end
Cheers!
Rob
08-01-2010 06:39 AM
Hi Guilherme,
1. enable
4. digit number
9. end
Cheers!
Rob
