MeetMe strange request on CUCM 6.1.2
Aug 1st, 2010
Hi All,
My customer here needs when leaves meetme conference all other participants who had joined the conf. to be dropped,the same like AD HOC conference.
I have CUCM 6.1.2
Any Ideas,
Ahmed Kamal
Marcos Assakawa Wed, 08/04/2010 - 13:58
Hi Ahmed, The CUCM does not support that feature with MeetMe. It only works with Ad Hoc conference. I hope this helps. Marcos
Wesley Sisk Thu, 08/05/2010 - 07:07
This may be possible if the individual is the meetme conference initiator. I have not tested this but it is the only way i am aware of that might possibly allow your desired workflow.
CM Service parameters off the option to maintain or drop a conference when conference originator leaves the conference.  Set this option to drop conference when originator leaves.  Then make sure your user is the meetme conference initiator.  It's worth a test.  If it does not work then I believe Marcos' point about adhoc behavior definitely follows the behavior configured in this service parameter.
