08-01-2010 10:50 AM
Hi All,
Here is an interesting one. Got a selection of Compliance management jobs and am having trouble with the deploy phase. Basically I am looking for the following on a series of devices and then removing it.
- [#radius-server host.*#]
So when this runs, it matches what I expect (shown below)
no radius-server host x.x.x.x auth-port 1812 acct-port 1813 key 7 XXXXXXXXXXXX
However when I deploy this, the line above remains on the device?
I have tried changing the compliance check to
- radius-server host x.x.x.x auth-port 1812 acct-port 1813 key 7 XXXXXXXXXXXX
To see if its a regex problem of some form and the job does exactly the same, i.e. it matches the line and tries to deploy however doesn't work?
Any ideas?
08-01-2010 12:41 PM
If you're on RME 4.3, this could be CSCta80687, which will be fixed in LMS 4.0 - http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta80687
08-01-2010 01:46 PM
Hi Yidabear,
Its not a pre-requisite problem as the pre-requisites are fillfilled and hence it deploys the rest of the config to the devices in question. For some reason it is just this one line that it has a problem with. Strangely enough, we had a similar issue with the same format of TACACS server line. It seems to happen when you have the "key 7 xxxxxxxxx" value at the end? Even though it finds it and tried to remove it it fails.
08-17-2010 10:41 PM
Are you saying that if you type:
The device does not remove the line? That sounds like an IOS problem to me.
