Cisco 827 flash problem
Aug 1st, 2010
I have a Cisco 827-4V with 16MB flash, but if i try to copy a file larger than 8MB it gives me an error that there is no space.
But the 4 extra megas are there. I need this space to boot 12.4 IOS that are bigger than 8 MB.
Does anybody knows what would be happening?
Here is some information:
sh flash:
System flash directory:
No files in System flash
[0 bytes used, 12320764 available, 12320764 total]
12288K bytes of processor board System flash (Read/Write)
sh flash: summary
Partition   Size    Used      Free      Bank-Size  State          Copy Mode
  1        12031K      0K    12031K     1024K      Read/Write     Direct
                                     +  1024K
                                     +  1024K
                                     +  1024K
                                     +  1024K
                                     +  1024K
                                     +  1024K
                                     +  1024K
                                     +  4096K
It seems that the last block (4096K) can't be mixed with the others (1024K)
Thank you,
Andoni.
txopa1974 Mon, 08/02/2010 - 08:50
Thank you for your fast answer  leolaohoo !!
I will saw you what I'm talking about
Router1#del flash:c820-v6y6-mz.123-26.bin
Delete filename [c820-v6y6-mz.123-26.bin]?
Delete flash:c820-v6y6-mz.123-26.bin? [confirm]
Router1#sh flash:
File  Length   Name/status
  1   6918948  c820-v6y6-mz.123-26.bin [deleted]
[6919012 bytes used, 5401752 available, 12320764 total]
Router1#squeeze flash:
Squeeze operation may take a while. Continue? [confirm]
squeeze in progress... eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Squeeze of flash complete
Router1#sh flash:
Router1#copy tftp: flash:
Address or name of remote host [192.168.1.2]?
Source filename [192.168.1.2]? c820-k9osv6y6-mz.123-8.T11.bin
Destination filename [c820-k9osv6y6-mz.123-8.T11.bin]?
Accessing tftp://192.168.1.2/c820-k9osv6y6-mz.123-8.T11.bin...
Erase flash: before copying? [confirm]n
Loading c820-k9osv6y6-mz.123-8.T11.bin from 192.168.1.2 (via Ethernet0): !!!!!!!
%Error copying flash:c820-k9osv6y6-mz.123-8.T11.bin (No space left on device)
Router1#sh flash:
  1   8388608  c820-k9osv6y6-mz.123-8.T11.bin [deleted]
[8388672 bytes used, 3932092 available, 12320764 total]
The size of c820-k9osv6y6-mz.123-8.T11.bin is of 10014940  bytes. And I have to boot it from tftp.
There is a workaround for this??
Thak you in advance.
Leo Laohoo Mon, 08/02/2010 - 14:54
This is wierd.
YOu can copy c820-v6y6-mz.123-26.bin but you can't copy c820-k9osv6y6-mz.123-8.T11.bin?  Have you tried copying another version of the IOS?
txopa1974 Mon, 08/02/2010 - 15:14
Hello leolaohoo,
I can copy c820-v6y6-mz.123-26.bin because is smaller than 8 MB (I think)
c820-v6y6-mz.123-26.bin      6918948 bytes
c820-k9osv6y6-mz.123-8.T11.bin      10014940 bytes
Thank you in advance,
Andoni.
Leo Laohoo Mon, 08/02/2010 - 15:44
Yes, but the flash is 12320764 size.  It's more than your 10mb IOS ... by the way, what TFTP client are you using?  Are you using TFTP32?
txopa1974 Mon, 08/02/2010 - 16:00
Look at the show flash: detail , it seems that the last bloxk size of 4 KB can't be mixed with the previous of 1KB. I don't know if it's posible to erase webflash: and add it to flash: it seems that the 827-4V is toos old  .
I use the tftp server tftpd-hpa package in my linux sustem (ubuntu), no tftp client, but iI have installed the tftp-hpa package too.
I hace copied other IOS to the flash, and it seems the only problem is to be bigger than 8MB.
Again, any workaround??
Andoni.
txopa1974 Tue, 08/03/2010 - 15:31
I have made a probe with a notebook and I've copied the file correctly to the notebook:
tftp> get c820-k9osv6y6-mz.123-8.T11.bin
getting from 192.168.1.2:c820-k9osv6y6-mz.123-8.T11.bin to c820-k9osv6y6-mz.123-8.T11.bin [octet]
Received 10014940 bytes in 44.2 seconds [1811104 bit/s]
tftp> quit
[email protected]-txiki:/tmp$ ls -lrt
-rw-r--r-- 1 andoni andoni 10014940 2010-08-04 00:27 c820-k9osv6y6-mz.123-8.T11.bin
Thank you again,
Andoni.
Leo Laohoo Tue, 08/03/2010 - 15:34
IF this is resolved, can you mark this topic as "Answered"?  Thanks.
txopa1974 Tue, 08/03/2010 - 16:49
The issue is not  resolved, I can copy from tftp server to my notebook, but I can't  copy from the tftp server to the flash memory of the router. That is what I need. I will try the tftp32 tftp server later.
Andoni.
