Need Help On Wan Issue & VPN
Aug 1st, 2010
Above is the Network of One of my customer. The issue is now they are using ADSL and they want to change it to DSL and create remote access Vpn on their network. So i install the new SHDSL card on cisco 2800 router and upgrarde the IOS to see the card. Now i can see theDSL controller card. But i am still confuse with configuration from my ISP given configuration. Here are their config.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
cisco#sh run
Building configuration...
Current configuration : 1063 bytes
version 1
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname cisco
no logging console
username cisco privilege 15 password 7 01100F175804
ip subnet-zero
ip dhcp excluded-address 10.10.10.1
interface Ethernet0
ip address 115.42.238.xxx 255.255.255.240
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl equipment-type CPE
dsl operating-mode GSHDSL symmetric annex B
dsl linerate
interface ATM0.1 point-to-point
description ethernetlink to 1M
ip address 115.42.204.xxx 255.255.255.252
ip nat outside
pvc 8/35
  oam-pvc 0
ip nat inside source list 1 interface ATM0.1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0.1
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
exec-timeout 120 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
password 7 13061E010803
login local
scheduler max-task-time 5000
end
In My Dsl card, I can only configure mode to ATM mode and ATM0/1/0 interface. But i do not have ATM0 interface. If i config DSL controller assume as  ATM0 it is okay?Moreover I cannot type command (DSL equipment type , DSL Linertate). If anyone know how to config on this one plz help me.
One more thing, i do want to do VPN on the window2k3 as Remote Access VPN with Preshared Key. If i do this one, which ports do i need to open on our ASA 5505. Please enlighten me. I am more on server side and not much exeperience on network. Thank you.
spremkumar Mon, 08/02/2010 - 03:42
The config provided by your SP is generic and you need to customize the same based on your hardware.
You need to make sure that you configure the right parameters as mentioned by your SP to avoid any issues while establishing the connectivity.
As you have mentioned you need to change the syntax to interface atm0/1/0 based on the wic card availability in your router.
All other parameters should be the same but you still can try out establishing the connectivity with the best max possible config noting down the config lines left our or unsupported by your device.
regds
