Are the ACLs in Cat3560 statefull or stateless?
Answered Question
Aug 1st, 2010
Hello
Are the ACLs in Catalyst 3560 works like stateful or stateless firewall in latest software version?
Correct Answer by Jon Marshall about 6 years 8 months ago
alexandrfedchenko wrote:
Hello
Alexandr
Standard and extended acls on all devices are stateless ie. they check each packet in isolation. You can use the keyword "established" in an extended acl for TCP connections to check the syn/ack in the packets and you can use reflexive access-lists which are a little more stateful although i'm not sure the 3560 supports reflexive acls.
Jon
Overall Rating: 5 (1 ratings)
CSCO11584685 Mon, 08/02/2010 - 05:30
AFAIK if you use reflexive ACL then it is statefull, if you use the normal ACL then it would be stateless.
Correct Answer
Jon Marshall Mon, 08/02/2010 - 08:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hello
Alexandr
Jon
alexandrfedchenko Mon, 08/02/2010 - 23:16
No, it isn't.
The switch does not support these Cisco IOS router ACL-related features:
Non-IP protocol ACLs (see Table 34-1) or bridge-group ACLs
IP accounting
Inbound and outbound rate limiting (except with QoS ACLs)
Reflexive ACLs or dynamic ACLs (except for some specialized dynamic ACLs used by the switch clustering feature)
ACL logging for port ACLs and VLAN maps
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swacl.html
Many thanks to all.
Related Content
