Busy Line
Aug 1st, 2010
Hi, i have problem with CCME,
i have two analog lines i connect them to fxo ports
voice port 0/0/0 has number 444444
voice port 0/0/1 has number 456789
anybody call at line extention 2001 rings normally
the problem is anybody pick up the phone and press on button 9 and dial number no body can use the other line so if i press on 9 the phone will show busy,
voice-port 0/0/0
connection plar 2001
caller-id enable
voice-port 0/0/1
caller-id enable
dial-peer cor custom
name calllocal
name callmobile
name callint
dial-peer cor list call-local
member calllocal
dial-peer cor list call-mobile
member callmobile
dial-peer cor list call-int
member callint
dial-peer cor list localuser
member calllocal
dial-peer cor list mobileuser
member calllocal
member callmobile
dial-peer cor list superuser
member calllocal
member callmobile
member callint
dial-peer voice 9 pots
corlist outgoing call-local
destination-pattern 94......
port 0/0/0
prefix 1
dial-peer voice 900 pots
corlist outgoing call-int
destination-pattern 90T
port 0/0/0
prefix 0
dial-peer voice 937 pots
corlist outgoing call-mobile
destination-pattern 9[3-7]......
port 0/0/0
telephony-service
max-ephones 40
max-dn 40
ip source-address 10.10.10.10 port 2000
auto assign 1 to 40
dialplan-pattern 1 9444444 extension-length 4
dialplan-pattern 1 9456789 extension-length 4
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
ephone-dn 1 dual-line
number 2000
ephone-dn 2 dual-line
number 2001
corlist incoming superuser
ephone-dn 3 dual-line
number 2002
ephone-dn 4 dual-line
number 2003
ephone 1
no multicast-moh
type 7945
button 1:1
ephone 2
no multicast-moh
type 7965
button 1:2
ephone 3
no multicast-moh
type 7945
button 1:3
ephone 4
no multicast-moh
type 7936
button 1:5
scheduler allocate 20000 1000
end
thanks for your help
Steven Holl Mon, 08/02/2010 - 07:21
The FXO port only can handle a single call at a time.  Hence, when you have an active call through 0/0/0, any subsequent attempts for calls in and out of that port will not work while the first call is still actively using that port.
If you want to sustain more than a single PSTN call at a time, you need to get another FXO circuit to terminate on this device, and add more dial-peers with equal preference to point out the new circuit.
-Steve Holl
kanaanhani Mon, 08/02/2010 - 07:32
Hi Steven,
Thanks for your reply, i am using 4 port FXO. Only 2 lines are connected
voice port 0/0/0 444444
voice port 0/0/1 456789
as i understand from your reply that i can only use one line at a time ?
if i have 4 land lines
444444
456789
567891
678912
This means that i need to buy four FXO modules and not use them on the same slot ?
If yes could kindly answer me why they put 4 port at each FXO module.
Steven Holl Mon, 08/02/2010 - 07:38
Each FXO port supports a single circuit, for a single call.  Wiring to each FXO port should be 2-wire, straight-through.  So a four port FXO card supports four active calls, via for separate circuits.
You only have dial-peers configured to go out a single port:
port 0/0/0
prefix 1
port 0/0/0
prefix 0
port 0/0/0
You need something like this:
port 0/0/0
prefix 1
port 0/0/0
prefix 0
port 0/0/0
dial-peer voice 19 pots
port 0/0/1
prefix 1
dial-peer voice 1900 pots
port 0/0/1
prefix 0
dial-peer voice 1937 pots
port 0/0/1
kanaanhani Mon, 08/02/2010 - 07:47
wow thanks for your rapid reply,
what i have is 2 land lines RJ11 connected to two different ports of CCME.
So i can use each one of them to make seperate calls, i have configured dial peers also for 0/0/1, but when i use any line the other one will give busy signal. what else should i do , also i am thinking to make the other line use button 7 of the phone to take the other line.
thanks
Steven Holl Mon, 08/02/2010 - 07:57
Your configuration isn't correct if you have dial-peers for both ports
and you can't have two concurrent outbound calls. You don't need to
have different access codes for the different ports. That's excessive;
the IOS call control API can handle this just fine.
Get the following:
sh voice call sum
sh run
sh dialplan number #
And collect the following debugs for the first and second outbound calls:
debug voip ccapi inout
debug vpm sig
-Steve
kanaanhani Mon, 08/02/2010 - 07:59
I need sometime to get this i will get back to u ASAP
