LSP Traffic Rate Counter
Consider i have multiple LSP paths in an mpls cloud.[for different destinations]
How to know the amount of traffic flow / byte switched on per LSP.
from a particular source to destination ?
Which command is used to view?
I need to calculate the traffic flowing per LSP (Like we do on a normal physical interface- Is this possible ?]
Cisco guys/Experts  please help
Pramod
Giuseppe Larosa Mon, 08/02/2010 - 13:10
  • Hall of Fame,
    Founding Member
Hello Pramod,
show mpls forwarding on P routers provides per LSP byte counters but you cannot discriminate per source.
be aware that if using BGP multiple services/traffic types are mapped to a single LSP with destination = remote PE node address
Hope to help
Giuseppe
