DMVPN Question
Aug 2nd, 2010
Does anyone know if it is possible to configure a router that is IOS DMVPN "SPOKE" to also be a IPSec remote access or Easy VPN client. Furthermore does anyone know of any documentation that shows describes an example of this set-up.
Rahul Govindan Mon, 08/02/2010 - 02:01
  • Silver, 250 points or more
I believe this can be done. The documentation is below.Also it is an excerpt from the doc teling it is possible.
When an existing Easy VPN deployment is based on Cisco IOS® Software and the customer wants to add DMVPN to the same hub. DMVPN  configuration can be added to the same hub without impacting the  existing Easy VPN setup. If the existing Easy VPN setup has clients  based on Cisco IOS Software routers, this setup can be converted into  DMVPN spokes if needed.
http://www.cisco.com/en/US/technologies/tk583/tk372/technologies_white_paper0900aecd80267995_ps6658_Products_White_Paper.html
You can also refer the following doc for dmvpn hub and ezvpn server on the same ios using profiles:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801eafcb.shtml
paultribe Mon, 08/02/2010 - 02:33
Hi, thanks for your response. I looked at this document earlier and this does describe how to configure a DMVPN "HUB" as an Easy VPN server but not specifically a "SPOKE".
Which section are you referring to.
