hwic-9esw is not properly fitting in Cisco 2811
Aug 2nd, 2010
Got 2811 router and HWIC-9ESW card.
When inserting in NM slot i.e. Big blank slot, it goes inside.
And is has screws on both ends horizontally whereas router has diagonally.
I think we have to mount this card on some chassi or assembly then fit into router.
pls suggest how to solve this issue?
Nagaraja Thanthry Mon, 08/02/2010 - 07:01
  • Cisco Employee,
I think you were trying to install the module on a NM slot. Since you are using a HWIC, it should go to the HWIC slot. HWIC-9ESW is of 2 slot form factor. So, you need to remove the slot divider in the HWIC slots and then insert the module. Here is the procedure to remove the slot dividers.
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/09_hw.html#wp1030687
Here is the procedure to install the HWIC-9ESW card.
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/inst_ic.html#wp1037339
Hope this helps.
NT
Related Content
