Amazon EC2 Virtual Private Cloud and Cisco ASA 5520
Aug 2nd, 2010
Hi there.
I am currently trying to create a site-to-site VPN with an Amazon EC2 Virtual Private Cloud (VPC).  When creating the VPC with Amazon you enter all your connectivity details and it generates a Cisco IOS config file which is great.  I am using a Cisco ASA 5520 (software version 7.2(2)) with ASDM 5.2 (3).
The problem occurs when I try to either load the config that Amazon has supplied (TFTP) or enter it manually.  I get invalid input errors.  The config generated by Amazon is attached (please note certain parts have been hashed out for security, but I am working from a config with all the correct details).
I'm not sure if I'm doing things wrong or whether the ASA doesn't support the functionality required but I'm a bit stuck.  I know my way around the ASDM quite well but I'm a little rusty when it comes to the IOS.
Any help would be much appreciated.
Many thanks
Paul.
mulatif Tue, 08/03/2010 - 10:08
Hi Paul,
The config generated is for an IOS Router and that is why it won't work "as it is" on the ASA.
The router config involves VRF, BGP , GRE and none of these are supported on the ASA.
ASA can setup a regular Lan-2-Lan tunnel but you will need to check with Amazon, if they support it.
Naman
