PTMServer.log size issues
Aug 2nd, 2010
I have a problem with PTMServer.log. It is getting filled with the bellow messages. I have checked https://supportforums.cisco.com/message/667827 discussion and it seems to be identical error message. I have checked "Disable All Threshold Settings for This Group" Tick Box as Joe suggested in the thread and all the boxes are unticked.
If you have any suggestion I am all yours
We are running 3.2 version of DFM. See the screenshot attached. The box is Win2003 R2 SP2 (VMware)
02/Aug/2010 10:06:08:783 ERROR main com.cisco.nm.xms.ctm.client.CTMCall establishIPC  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
02/Aug/2010 10:06:08:783 ERROR main com.cisco.nm.xms.ctm.client.CTMClientProxy getProxy  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
Mon Aug 02 10:06:16 BST 2010 PTAProxy :: Exceptions in PTSettingDetails() :: com.cisco.nm.vhm.vpta.PTAException: PTARequestHandler :: in PTSettingDetails() ::com.cisco.nm.inchargelib.InchargeWrapperException: MR-E-OBJECT_NOT_FOUND_EX-Cannot find object
    'SelectiveConfiguration::CFG-Polling Groups'
MR-CALL_ON_NULL_OBJECT-Tried to make a call on a NULL repository object; in
    file
    "H:/FOUNDATION-7.0.2.X-HF/44/smarts/repos/servif/SM_RepositoryServer.c" at
    line 1126
[ERROR:com.cisco.nm.vhm.vpta.PTAException: com.cisco.nm.vhm.vpta.PTAException: PTARequestHandler :: in PTSettingDetails() ::com.cisco.nm.inchargelib.InchargeWrapperException: MR-E-OBJECT_NOT_FOUND_EX-Cannot find object
    file
    line 1126
at com.cisco.nm.trx.ptm.server.PTInformer.sendOrderedPTAdapterDataToPTA(PTInformer.java:99)
at com.cisco.nm.trx.ptm.server.PTInformer.processPTInformerQ(PTInformer.java:65)
at com.cisco.nm.trx.ptm.server.GroupUpdates.databaseUpdate(GroupUpdates.java:99)
at com.cisco.nm.trx.ptm.server.GroupUpdates.run(GroupUpdates.java:44)
Mon Aug 02 10:06:20 BST 2010 PTAProxy :: Exceptions in PTSettingDetails() :: com.cisco.nm.vhm.vpta.PTAException: PTARequestHandler :: in PTSettingDetails() ::com.cisco.nm.inchargelib.InchargeWrapperException: MR-E-OBJECT_NOT_FOUND_EX-Cannot find object
    'SelectiveConfiguration::CFG-Interface Groups'
    file
    line 1126
    file
    line 1126
at com.cisco.nm.trx.ptm.server.GroupUpdates.processActionGroupNameHashtable(GroupUpdates.java:354)
at com.cisco.nm.trx.ptm.server.GroupUpdates.run(GroupUpdates.java:76)
Mon Aug 02 10:06:34 BST 2010 PTAProxy :: Exceptions in PTSettingDetails() :: com.cisco.nm.vhm.vpta.PTAException: PTARequestHandler :: in PTSettingDetails() ::com.cisco.nm.inchargelib.InchargeWrapperException: MR-E-OBJECT_NOT_FOUND_EX-Cannot find object
    file
    line 1126
    file
    line 1126
                 Martin
Martin Smid Thu, 11/18/2010 - 02:12
Yes. This has been resolved by Cisco TAC. I don't want to go into technical details, because it was fixed a while ago and I don't want to desinform you. If you raise a TAC request the engineer should be able to help you out. The problem is that it will wipe the config for your DFM and you will need to setup the alerts and notification from the scratch.
Martin
Related Content
