Router Phone Home Updates
Aug 2nd, 2010
We are about to deploy 200+ 871 routers for our home based users and have ran into a snag.  Periodically we would like to update the information on these routers, such as username password, IOS, syslog servers, etc.
Does anyone out there have a solution for updating the configuration on remote equipment?  Ideally a router would come online using Easy VPN, connect back to our ASA, check to see if there is a new config available or commands awaiting it and execute.
Thanks in advance.
Collin Clark Mon, 08/02/2010 - 06:28
You could setup a cron job to download a file from a server, then apply it to the running config. You can probably do it with EEM as well.
Hope it helps.
Phillip Remaker Fri, 08/20/2010 - 14:48
Look also at the Cisco Command Scheduler, which we call "kron"
You can set that to run commands on a schedule, including commands like
copy tftp://x.x.x.x/foo.cfg startup-config
(which takes place at the next reboot)
copy tftp://x.x.x.x/foo.cfg running-config
to take place right away.
You can also do reloads and "copy run start" that way, too.
