MARS sudden failure
Answered Question
Aug 2nd, 2010
Dear All,
I have MARS device which suddenly couldn't be reached through network and couldn't collect events.
when i checked its console through Video , i found alot of faults and at the last line i found this message:
Fatal Exception:panic in 5 seconds
"Kernet panic - not syncing : Fatal Exception"
attached is a picture for the rest of the messages.
Can anyone tell me about this as this is not a normal behavior.
Thanks in Advance,
Ayman Yehia
Correct Answer by musaeed about 6 years 9 months ago
Hi Ayma,
This is a rare condition usually seen when the system fails the memory and file system checks. If you reboot it; it should relieve this condition for the time being as more fs checks are done at startup. Depending on your software version, you maybe running into a software bug as there are several bugs with similar symptoms in versions older than 6.0.7. If you haven't already done so, please upgrade your Mars appliance to the latest 6.0.7.
Potential Bug:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
CSCsm40349
Rare crashing issue due to file system check/memory short
Resolved in 6.0.7.
Please refer to the bug toolkit for more information regarding this bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsm40349
Mars upgrade packages are available below:
http://www.cisco.com/cgi-bin/tablebuild.pl/cs-mars
Hope it helps,
~Badar
Overall Rating: 5 (1 ratings)
Correct Answer
musaeed Mon, 08/02/2010 - 12:12
Hi Ayma,
Potential Bug:
CSCsm40349
Resolved in 6.0.7.
Hope it helps,
~Badar
ayman emara Mon, 08/02/2010 - 22:29
Hi Badar,
Thanks for your reply.
my MARS version is 6.0.3. it is not mentioned in the bug affected version.
but if it happened to me again i'll go on the upgrade process.
Thanks again.
Ayman Yehia
musaeed Tue, 08/03/2010 - 09:57
You are welcome Ayman. Your Mars version 6.0.3 may also be affected. Please refer to the release notes excerpt below:
Conditions:
This issue has already been observed on  MARS boxes running software versions 4.3.1, 5.2.3, 5.2.4 and 6.0.1.  Other versions are likely to be affected as well.
