WRVS4400N Configuration for VOD
Aug 2nd, 2010
I recently bought the WRVS4400N router and have troubble configurating the QoS for the VOD of my ISP.
Original topology:
The original internet router (Motorola) was provided by my ISP and the box for the VOD was directly connected through local network.
Now I configured my new WRVS4400N to by used as the gateway and use the original Motorola router as bridge for the internet access. Everything works fine for the internet but the VOD does not work properly. When I started it, I works for 2 minutes and stops until I change channel. Then it also work for a couple of minutes. I seems to me that it's like a QoS issue, but the problem is happening even with no "normal" internet traffic.
Does somebody have experience or documentation about VOD/QoS/Multicasting with the WRVS4400N?
All kind of help would be hightly appreciated
