QoS - Bandwidth Control
Hello Experts,
we are using a couple of 4404 Controllers with software version 6.0.188.0. We would like to introduce the wifi and wired Portal to our custumers. During our testing period we discovered a little problem with the Bandwidth Control via QoS.
These are our settings:
Description...................................... For Portal (Background)
Average Data Rate................................ 512
Burst Data Rate.................................. 512
Average Realtime Data Rate....................... 256
Realtime Burst Data Rate......................... 256
Maximum RF usage per AP (%)......................  50
Queue Length.....................................  25
protocol......................................... none
If we download a file the bandwidth restriction works fine. We get a downstream about 62 kB/s. If we upload a file the bandwidth restricion seems not working. We get an upstream about 1660 kB/s.
Are we missing something? Is there a setting to control the upstream behavior independent from downstream?
Thanks a lot, best regards,
   Mathias, Michael
rydsouza Fri, 08/13/2010 - 16:37
  • Cisco Employee,
The settings described are for over-the-air bandwidth. The Ap can only control downstream QoS or data that it sends. Upstream QoS will be handled by the client device and cannot be controlled by the Ap. The Ap cannot enforce QoS settings for upstream traffic.
Trending Topics - Security & Network
