Firmware upgrade an Active/Passive Pair of Firewalls
Answered Question
Aug 2nd, 2010
I have several sets of firewalls running active/standby that I want to upgrade from 8.0.5 to 8.2.2. According to the cisco docs to do this without downtime (which as they are running live web services is required) I need to go from the 8.0.x release to 8.1.x and then onto 8.2.x.
All well and good but there aren't any 8.1.x images available to download.
So can I go from 8.0 to 8.2 without downtime in between the upgrades? Or if not have you any suggestions on how I can do this.
Correct Answer by Rahul Govindan about 6 years 5 months ago
you can go from 8.0x to 8.2x directly without any downtime. the same zero dowtime upgrade can be performed. the doc is
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/mswlicfg.html#wp1057338
Correct Answer by Nagaraja Thanthry about 6 years 5 months ago
8.1 code line is available only for 5580 platform. Since you are going from
8.0(5) to 8.2, you can follow the zero downtime upgrade procedure.
http://cisco.biz/en/US/docs/security/asa/asa82/release/notes/asarn82.htm...
315678
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/a...
_swconfig.html#wp1053398
Hope this helps.
NT
Overall Rating: 5 (2 ratings)
bgl-group Mon, 08/02/2010 - 08:42
Thanks for that - should make getting the upgrade through our change process a bit easier.
