WS-C3550-24-PWR 'Insufficient Power'
Aug 2nd, 2010
I have a Catalyst 3550 with PoE (WS-C3550-24-PWR) that has 1 x AP 1220 connected using PoE.  When I add 2 x AP 1242s, I get an insufficient power message.  How many devices using PoE can this switch support?  I'm running IOS v.12.1(19)EA1c - could this be an IOS update issue?  Thank you in advance.  -Jason
Nagaraja Thanthry Mon, 08/02/2010 - 09:00
  • Cisco Employee,
If you issue "show power inline", it will tell you the amount of power
delivered and the amount of power remaining. Typically the switch will have
360W of power and it can deliver 15.4 W per interface (max).
Hope this helps.
NT
jasonpgutierrez Mon, 08/02/2010 - 09:58
Thanks for responding.  See below for the results of the 'show power inline'-
----snip--------------------
Interface  Admin    Oper     Power        Device           Class
                            (Watts)
Fa0/1      auto  on            6.2  cisco AIR-AP1220-IO  n/a
Fa0/2      auto  on           15.0  Ieee device
Fa0/3      auto  on           15.0  Ieee device
Fa0/4      auto  off           0.0  n/a                  n/a
Fa0/5      auto  off           0.0  n/a                  n/a
Fa0/6      auto  off           0.0  n/a                  n/a
Fa0/7      auto  off           0.0  n/a                  n/a
Fa0/8      auto  off           0.0  n/a                  n/a
Fa0/9      auto  off           0.0  n/a                  n/a
Fa0/10     auto  off           0.0  n/a                  n/a
Fa0/11     auto  off           0.0  n/a                  n/a
Fa0/12     auto  off           0.0  n/a                  n/a
Fa0/13     off   off           0.0  n/a                  n/a
Fa0/14     off   off           0.0  n/a                  n/a
Fa0/15     off   off           0.0  n/a                  n/a
Fa0/16     off   off           0.0  n/a                  n/a
Fa0/17     off   off           0.0  n/a                  n/a
Fa0/18     off   off           0.0  n/a                  n/a
Fa0/19     off   off           0.0  n/a                  n/a
                            (Watts)
Fa0/20     off   off           0.0  n/a                  n/a
Fa0/21     off   off           0.0  n/a                  n/a
Fa0/22     off   off           0.0  n/a                  n/a
Fa0/23     off   off           0.0  n/a                  n/a
Fa0/24     off   off           0.0  n/a                  n/a
Below is the power draw on the AP from Cisco's website -
------snip-------------------
12.95W maximum
Note: 12.95W is the maximum power required at the powered device. If the access point is being used in a PoE configuration, the power drawn from the power sourcing equipment will be higher by some amount dependent on the length of the interconnecting cable. This additional power may be as high as 2.45W, bringing the total system power draw (access point and cabling) to 15.4W.
Based on this info, all should be ok.  Any ideas on what else to check?
-Jason
Nagaraja Thanthry Mon, 08/02/2010 - 10:12
  • Cisco Employee,
Can you please post the output of "show power inline", "show interface
NT
rahurao Mon, 08/02/2010 - 11:44
Hi Jason,
As per the output it only shows that the you have 3 devices connected and drawing power from the switch which is normal and the switch should be fine.
Can you send me the show power output and also can you let me know what device you are trying to conect and what is the minimum pwer requirement for the same.
Rahul
jasonpgutierrez Mon, 08/02/2010 - 12:08
Rahul,
See below for requested info.  The APs are 1242s.
                            (Watts)
                            (Watts)
Power Draw for 1242
12.95W maximum
Please let me know if you need additional info.
-Jason
Nagaraja Thanthry Mon, 08/02/2010 - 12:13
  • Cisco Employee,
Which port you have connected the AP to? Also, in the output you have sent,
we are missing the total power details.
3550_1#sh power inline
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
rahurao Mon, 08/02/2010 - 12:16
Hi Jason,
Thanks for the update!
Where as you have not provided the total power and power available in the show power inline output. Please share the same!!
How many AP's are we trying to connect to the switch at a time.
RAHUL
jasonpgutierrez Mon, 08/02/2010 - 12:23
Rahul,
The command does not give me the total power.
There is currently one AP on the switch (on port 1).  I added 2 x 1242s on ports 2 & 3.
I am going to upgrade the IOS tomorrow and see if that helps.
-Jason
rahurao Mon, 08/02/2010 - 12:25
Hi Jason,
Can you just give me the complete output of the show power inline ?
Rahul
jasonpgutierrez Mon, 08/02/2010 - 12:30
See below -
-----snip-------
switch#sh power inline
                            (Watts)
                            (Watts)
switch#
-Jason
rahurao Mon, 08/02/2010 - 12:35
Hi jason,
This is weired ! you are not getting the complete outputs with the commands. We are really not sure how much power it is consuming and how much is available.
Please proceed with a reload or upgrade and let me know the updated status on the same.
Rahul
Nagaraja Thanthry Mon, 08/02/2010 - 12:54
  • Cisco Employee,
Hello Jason,
The issue seems to be hardware related. In order for us to narrow down the
problem, please follow the below troubleshooting steps:
Step 1: Disconnect the AP in question
Step 2: Configure logging on the switch
configure terminal
logging on
logging buffered debugging
Step 3: Enable inline power debugs
switch# debug ilpower events
Step 4: Now connect the AP in question and wait for a minute
Step 5: Now collect the output of "show log"
The output will show us the negotiation between the AP and the switch with
regard to the power requirements. Typically, the switch will reject power
allocation if the AP is asking for power beyond what switch can provide or
if it does not recognize the AP at all. Once we figure out what is the root
cause, it is easy to find a fix.
Hope this helps.
NT
Leo Laohoo Mon, 08/02/2010 - 15:12
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Upgrade to what?  There are two directions.  You can upgrade to either 12.1(22)EA13 or 12.2 series.  If you have the service contract, upgrade to the 12.2 instead (IP Base).
jasonpgutierrez Tue, 08/03/2010 - 08:01
I upgraded the switch to the latest IOS (v12.2(44)SE6) and that resolved the problem.  The  APs can connect and I can see the power stats.  See below -
----snip-----
Available:360(w)  Used:37(w)  Remaining:323(w)
                            (Watts)
Fa0/1     auto   on         6.2     AIR-AP1220-IOS-UPGR n/a   15.4
Fa0/2     auto   on         15.4    Cisco PD            n/a   15.4
Fa0/3     auto   on         15.4    Cisco PD            n/a   15.4
---snip------
Thanks to all for your input.
-Jason
