IPC Set Variable Action UCCX
Aug 2nd, 2010
  • Bronze, 100 points or more
we are using a IPC to comunicate CAD with a third party application. We are using IPC Set Variable Action, but it seem that it doesn't work correctly. Indeed of we have tried IPC Make Call Action and it works fine. I'll try to explain myself as clear as I could:
  • We have a ECC Variable named user.Idioma.
  • This ECC variable is included into a layout and it showed in it as Idioma with the correct value.
  • From the external third party app we send to the CAD app the following code:
    • <?xml version="1.0"?><IPCActions><IPCSetVariableAction><ActionName>IPC Set Variable Action</ActionName><Variable>user.Idioma</Variable><DataValue>english</DataValue></IPCSetVariableAction></IPCActions>
Although we send the xml code, the variable is not modified.
Could anybody help us with this?
Overall Rating: 4 (1 ratings)
psalvador Tue, 12/14/2010 - 11:27
Hi Antonio
We are experiencing the same issue.
How did you overcome this problem?
Thank you
antonio.vazquez Wed, 12/15/2010 - 00:58
we have solve it setting the variable as follows:
user.Idioma|Idioma
Using both fields concatenated with a pipe.
HTH.
If this works please rate it.
psalvador Wed, 12/15/2010 - 09:50
Thank you very much for the tip. It works using the following format:
...Field Name|Display Name ...
We are experiencing another issue, which is related with the refresh of Layout fields in CAD.
When the variable is changed using the IPC Set Variable, it's value is not refreshed in CAD. Have you solved this issue?
Thank you and regards
antonio.vazquez Thu, 12/16/2010 - 04:43
you are experiencing the correct functionality. You will only view variables refreshed when you transfer the call to a new destination (for example an other agent).
Varibles values never be refreshed in your own desktop.
Antonio
If you found this post helpful, please rate it.
polat.taskin Tue, 07/16/2013 - 03:04
Do not change this value?
My scenario is;
call comes agent (callvariable2 set english by IVR), Agent start a conference call with authentication IVR.
when the call conference then The value must be replaced new value
Related Content
