NOSServer is not Running on DFM 3.2
Aug 2nd, 2010
Hi all,
We have a CiscoWorks LMS 3.2 with DFM 3.2 on a Windows Server 2008 ServicePack 2. We reregister the NOSServer for another problem but after that process didnt start. Can you help me to reregister de NOSServer properly
Thanks for your help
Rafael Turriago
rafael.turriago Mon, 08/02/2010 - 18:46
Hi Joseph thanks for your help...This is the pdreg command output:
C:\>pdreg -l NOSServer
        Process      = NOSServer
        Path         = C:\PROGRA~1\CSCOpx\bin\cwjava.exe
        Flags        = -server -cp:p MDC\tomcat\webapps\triveni\WEB-INF\lib\log4
j.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\nos.jar,MDC\tomcat\webapps\triveni\
WEB-INF\lib\ctm.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-client.jar,MDC\to
mcat\webapps\triveni\WEB-INF\lib\cogs.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib
\ogs-kc1.0.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kilnervirtualasa1.0.ja
r,MDC\tomcat\common\lib\activation.jar,MDC\tomcat\common\lib\mail.jar,MDC\tomcat
\webapps\triveni\WEB-INF\lib\tis-client.ja,MDC\tomcat\webapps\triveni\WEB-INF\li
b\pm.jar,lib\classpath\jconn2.jar,lib\classpath\epm-v0-5-0.jar,lib\classpath\ces
ar-v0-5-0b.jar,MDC\tomcat\shared\lib\NATIVE.jar,MDC\tomcat\shared\lib\MICE.jar,M
DC\bin,objects\nos\config,MDC\tomcat\webapps\triveni\WEB-INF\classes,-cw:jre C:\
PROGRA~1\CSCOpx\lib\jre -cw:xrs -Djava.compiler=NONE com.cisco.nm.trx.nos.server
.NOSServer
        Startup      = Started automatically at boot.
        Dependencies = EPMDbEngine EPMServer INVDbEngine PMServer DFMOGSServer
regards
Rafael Turriago
Joe Clarke Mon, 08/02/2010 - 21:07
All of the commas here should be semi-colons.  How did you re-register this daemon?
rafael.turriago Tue, 08/03/2010 - 07:21
This is the command that I excecuted
C:\PROGRA~1\CSCOpx\bin\pdreg.cmd -r NOSServer -d "EPMDbEngine,EPMServer,INVDbEngine,PMServer,DFMOGSServer" -e C:\PROGRA~1\CSCOpx\bin\cwjava.exe -f "-server -cp:p MDC\tomcat\webapps\triveni\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\triveni\WEB-NF\lib\nos.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-client.jar;MDC\to
mcat\webapps\triveni\WEB-INF\lib\cogs.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kc1.0.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kilnervirtualasa1.0.jar;MDC\tomcat\common\lib\activation.jar;MDC\tomcat\common\lib\mail.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\tis-client.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\pm.jar;lib\classpath\jconn2.jar;lib\classpath\epm-v0-5-0.jar;lib\classpath\cesar-v0-5-0b.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\bin,objects\nos\config;MDC\tomcat\webapps\triveni\WEB-INF\classes;-cw:jre^C:\PROGRA~1\CSCOpx\lib\jre^-cw:xrs^-Djava.compiler=NONE com.cisco.nm.trx.nos.server.NOSServer"
Rafael Turriago
Joe Clarke Tue, 08/03/2010 - 09:02
This looks right provided this was executed on one line, and there are no stange breaks.  Post the NOSServer.log and the syslog.log.
rafael.turriago Tue, 08/03/2010 - 12:02
Hi Joseph
I checked the command excecuted before and I made a mistake. The NOSServer is working now
Thanks four your Help
Rafael Turriago
