Problem install license in a UNITY Express 8.0
Aug 2nd, 2010
i've got this problem on my service router 2951 with a NME-CUE Unity Express v 8.0.
I've got the PAK file and enter on cisco.com/go/license to get the .lic file to install in the unity module,  but when i run the command that is specified in the mail delivered by cisco appears this:
I'm using the evaluation license for 10 days and i need to install the license to activate the voice MBX
se-my_unity# [email protected]/FOC14162PKH_20100730153717069.lic
% Error: License installation failed with error: XML parsing failed
Can you help me with this problems.
mohamed.afifi Tue, 09/11/2012 - 00:31
I have the same issue with ISM-SRE running Unity Express 8.6
I used the PAKs to obtain the license files and tried to install from a remote ftp server and also from the router as a tftp server.
Any help on this one is highly appreciated.
here is the only error message I get:
Jason Aarons Tue, 06/17/2014 - 18:44
  • Bronze, 100 points or more
I'm running into a problem with CUE 8.6.6 on SRE-300.  The file was unzipped and i can see from either my TFTP server or FTP that the file is being correctly served.
Did you ever get a fix?  The other suggestions have not panned out.
