Need help Troubleshooting 3550 Switches
kennethpenrose1
I am having trouble pinging through my 3550 Core Switch, my CS is linked to 5 other 3550 switches via fibre.
What im trying to do is to ping my remote site which is on another subnet. I am able to ping and tracert my core switch how ever I am unable to go past my CS. Please could you help me troubleshoot this.
1) I am able to ping the CS
2) I can ping the Default Gateway
3) I am able to ping devices other than the switches in the remote site
4) I am able to remotly administer my CS but unable to access the other switches unless i am on that subnet.
5) CS fibre links are set to trunk ISL
Switches in use are
1 x WS-C3550-12G (CS)
2 x C3550 - 24
3 x C3550 - 48
What could be stopping me access my switches in the remote site?
Thank you
K
Since you are not routing on these switches, can you remove the following command and try.
ip route 0.0.0.0 0.0.0.0 10.x.x.x
Since you already have default-gateway we should be good.
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K11518475
JayaKrishna
7 Replies 7
Jayakrishna Mada
K,
what is the remote subnet that you are trying to reach ?
Post show ip route command and show run (with intefaces numbers facing your remote site ) outputs from your Core switch.
Are you able to ping the remote site switch from the CS switch ?
Is there any firewall or access-list that is in the path, which could be causing this ?
JayaKrishna
Hello JayaKrishna
The remote subnet is 255.255.255.0
I will post the sh ru and rout info in the morning.
xxxxxxxxxx#sh ip route
Default gateway is 10.x.x.x
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
Output is from my Core Switch
SWxxxxxxxxx#sh ru
Building configuration...
Current configuration : 2905 bytes
! Last configuration change at 12:36:49 GMT Mon Aug 2 2010
! NVRAM config last updated at 12:14:27 GMT Mon Aug 2 2010
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname xxxxxxxxxxxxxx
enable secret 5 xxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxx
username terminator
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
ip subnet-zero
spanning-tree mode pvst
interface GigabitEthernet0/1
switchport mode dynamic desirable
flowcontrol send off
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
duplex full
speed 100
interface GigabitEthernet0/12
interface Vlan1
ip address 10.x.x.x 255.255.255.0
ip default-gateway 10.x.x.x
ip classless
ip http server
end
Yes I am able to ping remote switches from the CS
There are no access lists on the switch and the firewall is allowing access to the remote site ( I am able to reach PC's and other equipment inside the remote LAN
Thank you
K
kennethpenrose1
Come on guys... Does no one have any ideas???
JayaKrishna
Hi there,
thanks for your help, I removed the route but it still didnt work but it got me thinking. there was a ip routing command on the switch once it was removed i could reach my switches.
Thank you again
K
   If you have one switch doing the routing then all other switches do not need ip routing turned  on in which case you would use the ip default-gateway command on the remote switches and not the ip route command.
Do the remote switches have default gateways also? Do the remote sites know how to get to your user LAN IPs?
I know the core switch can ping, which is sensible. But if your client systems cant ping the remote switches, it is likely they don't know how to get back to the IP subnet of your client system.
Just a thought...
