Cisco 827H router/modem.
Aug 2nd, 2010
Hi all.
I have bought this unit second hand with all the bits and pieces and manual.
When trying to set it up via my computer, I canoot access the router with the normal http://10.10.10.1 ip address.
Can anyone give me some help please.
I know nothing about these Cisco units.
Cheers.
Tim.
timlumsden Mon, 08/02/2010 - 19:33
Hi Leolaohoo
Thanks for the reply but that address did not connect to the router.
I have the RDX and TDX lights on as well as the OK and ethernet4 (upt cable to PC).
Cheers.
Tim.
Leo Laohoo Mon, 08/02/2010 - 19:41
Console into the router.  The link I posted gives you instructions on how to conduct password recovery.
Nagaraja Thanthry Mon, 08/02/2010 - 19:44
Have you configured your PC to get an IP via DHCP? If yes, what IP did you
get? The address you are using (10.10.10.1) is the correct address to access
the router. Can you please follow the troubleshooting steps listed here:
If the CRWS home page does not appear when you enter the URL
http://10.10.10.1, test the connection between the PC and the router by
doing the following:
1. Check that the OK LED on the router is on, and check the cable connection
between the router and the PC. Be sure that the TO HUB/TO PC button is in
the correct position. The button is in the correct position if the LED for
the port on the front of the router is on.
2. If the CRWS home page still does not appear, verify that the web
browser's "work offline" option is disabled.
3. If the web page still does not appear, verify that your PC is
automatically configured to receive an IP address. Follow the instructions
in the Cisco Router Web Setup Troubleshooting Guide, which is available on
the Cisco 800 and SOHO Series Product Documentation CD.
4. If the PC is configured to automatically receive an IP address, but the
web page still does not appear, select Start/Run, type winipcfg in the Run
window, and examine the address in the IP address field. The address should
be in the format 10.10.10.X, in which X is a number that is equal or greater
than 2; for example, 10.10.10.2, or 10.10.10.3. If the IP address is not in
this format, verify that an Ethernet adapter name is visible in the Adapter
field. If there is no name in the field, return to Step 3 in "Checking the
PC Configuration," add TCP to the list of protocols. Then return to "Using
Cisco Router Web Setup to Configure the Router," and complete the procedure.
http://www.cisco.com/en/US/docs/routers/access/800/827/hardware/installa...
/guide/install.html#wp1033008
Hope this helps.
NT
timlumsden Mon, 08/02/2010 - 20:27
Hi.
Thanks for the help but still no go.
I have connected the router as per instructions.
It is set toPC and I have no ADSL cable connected, just the UPT cable to 4th lan and to PC.
All settings for the web browser are as you have suggested but no joy with http://10.10.10.1 to access router.
I have a "console cable" but the instructions for connection are a little beyond my understanding.
Do I have to have the RJ45 cable connected as well as the "console cable"?
How do I access the router via the "console cable"?
My computer does not see the file "winipcfg", will not work.
Cheers.
Tim.
Nagaraja Thanthry Mon, 08/02/2010 - 20:39
You can go to CMD prompt on the PC (Start --> Run --> CMD + Enter) and then
type "ipconfig /all". That will tell you the IP address on the PC.
For you to connect the console cable, you need to have a serial port on your
PC.
http://www.google.com/imgres?imgurl=http://www.ladyada.net/images/minipo...
erial_port.jpg&imgrefurl=http://www.ladyada.net/make/minipov3/software.html&
h=982&w=1310&sz=280&tbnid=EKmhMBs37z1EkM:&tbnh=112&tbnw=150&prev=/images%3Fq
%3DSerial%2Bport%2BPC&usg=__hyfWRVf5fBQfTurBOE86qAjNpAo=&sa=X&ei=no5XTLbkMpO
6sQPFgqiiAQ&ved=0CC0Q9QEwAw
Once you have connected the RJ45 side of the cable to the Router side and
the RS232 side to the PC, go to Start --> Accessories --> Communication -->
Hyperterminal. Then follow the wizard (give a name, select the comm port,
then in the next screen hit button). Now you should be
able to access the CLI.
Hope this helps.
NT
timlumsden Mon, 08/02/2010 - 21:13
Hi.
OK, I am in the console "hyper term" and rebooted the router while hitting the "break" key.
Lots of activity then I now have the option to "enter configuration dialog= yes or no?
Were from here please.??
Cheers.
Tim.
Nagaraja Thanthry Mon, 08/02/2010 - 21:22
Say "No". Then it will go to a prompt "Router>".
Then type "enable" and hit enter
Router>enable
Router#
Now enter configure mode by typing "configure terminal"
Router#configure terminal
Router(config)#
Now configure an IP address for the VLAN:
Router(Config)#interface VLAN 1
Router(config-if)#ip address 10.10.10.1 255.255.255.0
Router(config-if)#exit
Router(config)#
Now enable HTTP Server on the router:
Router(config)#ip http server
Now configure a username/password:
Router(config)#username cisco priv 15 password Cisco
Router(config)#enable password cisco
Now configure your PC with an IP address of 10.10.10.2. Connect the PC to
one of the ports (Fa 1 - 4) and you should be able to access the router via
web page.
Hope this helps.
NT
timlumsden Mon, 08/02/2010 - 21:43
Hi. Thanks for all your help but cannot get past config# interface VLAN 1 as it says invalid input detected at marker ^.
Must be some other command needed.
Cheers.
Tim.
Nagaraja Thanthry Mon, 08/02/2010 - 22:10
Are you in "Router(config)#" mode? Can you try configuring "Ethernet0"
interface and see if that helps?
Router(config)#interface Ethernet0
Router(config)#
Router(config)#username cisco priv 15 password cisco
one of the 4 ports and you should be able to access the router via web page.
Hope this helps.
NT
timlumsden Tue, 08/03/2010 - 15:27
Hi NT.
Thanks for all your help.
Nothing I have done seems to release the "web" interface within the router.
Can you tell me what able need to attached to the router:
1/ When the serial cable is used, do you attach any other cable? (apart from power)
2/ When you open a web browser to the router from PC, does the ADSL line need to be connected also.
3/ Is there any way of seeing the configuration within the router (connected to PC with serial) via the "Hyper Terminal" command line. I am very familiar with Linux systems.
This cisco unit is not logical to me at all.
Cheers.
Tim.
Nagaraja Thanthry Tue, 08/03/2010 - 15:36
Hello Tim,
Once you configured all the stuff that I mentioned yesterday, connect an Ethernet cable between the PC and the router (one of the four ports) and assign the PC an IP address of 10.10.10.2 mask 255.255.255.0. Now try to ping 10.10.10.1 address and see if you get a response. If you don’t, then through the HyperTerminal, issue the following command:
"Show interface Ethernet0"
You will see lot of outputs but the first line will say
"Ethernet0 administratively up line protocol is up"
If you see an output that is different from above (something like line protocol is down), then go to configuration mode and do a no shut:
Configure terminal
Interface Ethernet0
No shut
Exit
Now repeat the ping test and see if you get a response. After you verify ping connectivity, please issue the following command "show ip http server status" and post the output here.
Hope this helps.
NT
timlumsden Tue, 08/03/2010 - 23:06
Hi NT.
Got the router to show the RDX and TXD lights to show.
Still unable to communicate with router via firefox browser but it does try to connect then 'times out'.
Here is the "server status" in the router.
Nagaraja Thanthry Wed, 08/04/2010 - 05:56
From the router command line, can you please collect the following outputs and post it here:
Router> enable
Router#dir flash:
Router#show ip http server status
NT
timlumsden Wed, 08/04/2010 - 15:24
Hi NT.
I have a question.
If the router is to be reset to factory spec's. What config register do I use: 0x2142 or 0x2102 ?
I think the whole thing needs to be reset to "factory settings", if this will make the unit configurable.
Kindest regards.
Tim.
Nagaraja Thanthry Wed, 08/04/2010 - 18:24
Before you reset, can you please try the following:
Router(config)#exit
This will enable the http server. Now try accessing the router via http.
Also, if you reset the router, it will not change the configurations to factory default. It will erase it and you will have an empty box. Have you tried to reset the router before it stopped responding to HTTP requests?
Hope this helps.
NT
timlumsden Wed, 08/04/2010 - 18:58
Hi NT.
I tried your suggestion and still am unable to communiate with the router via a web browser, just times out each time.
I also turned off MS XP's firewall thinking that may help, but no.
I realy appreciate all your help.
Yes this unit has been played with before I got it, it was originally set up for Telecom New Zealand service provider then messed with.
I believe it has been reset at some stage before and probably that is why I am gaving so much grief.
If I was to reset to factory specs, perhaps I might learn more. In any case, there must be a way to access the unit via a web browser when the units were sold new.
I have access to the NZ setup "cookbooks" configurations.
Cheers.
Tim.
Nagaraja Thanthry Wed, 08/04/2010 - 19:23
I guess when they reset the router they removed necessary files for Web
access. Please download the CRWS files here and follow the procedure to
install the software.
Download the file at:
http://tinyurl.com/2ewvqzf
Installing CRWS:
http://tinyurl.com/2ebdjc3
Then, enable HTTP server on the router
That should allow you to access the web pages.
Hope this helps.
NT
timlumsden Wed, 08/04/2010 - 19:29
Hi NT.
Cisco will not allow me to download the file. Something to do with my registration.
Will look into it.
Cheers.
Tim.
timlumsden Wed, 08/04/2010 - 22:20
Hi NT.
Cannot get that file from Cisco site.
I have managed to get the other computer to talk to the router.
Changed some setting in the router and on the computer IP address, now I can ping the router with internet explorer 8.
I get a box come up saying "loading web browser configuration", please wait......
But it just sits there and nothing else happens, seems to be trying to load to no avail.
Cheers.
Tim.
