Cisco UCCX 7.0.1 Standard license Java support
Aug 2nd, 2010
Hi Guys,
I am having a problem when migrating the exsisting CRS scripts from 3.5 standard  to 7.0.1 standard. In one of old script, a  simple java function is used to calculate the length of the digits that was resulted from "get digit string " step.  But in UCCX 7.0.1 standard , I just tried to use the "?.length" function to calculate the length of the digits. but when I debug the script, the error is some license violations, I beleive that this is due to the standard license restrictions. Anybody can help how I can calculate the length of the digits in UCCX 7.0.1 with standard license. Appreciate your help on this. I am stuck in the migration due to this licensing issues?
Thanks ,
Suban.
Jonathan Schulenberg Tue, 08/03/2010 - 05:10
  • Cisco Designated VIP,
    2017 IP Telephony
AFAIK you can't. Standard is very handicapped in that regard and is rarely sold for that reason. Sorry to be the one to say it; but, you should upgrade to Enhanced.
