pass traffic between ezvpn client routers, with pix ezvpn server
Aug 2nd, 2010
hello,
I have a problem, I´m  configuring ezvpn client in router 881 with pix 515 how ezvpn server, the vpn is established between pix and router, and I can ping the lan in the pix from the router ezvpn client, mi problem is that I can´t ping between 2 router 881 ezvpn clientsCaptura1.PNG
can you help me
regards
Jitendriya Athavale Mon, 08/02/2010 - 21:38
also you might need the following
for 8.2.1 and earlier
static (outside,outside) norandom-seq nailed
static (outside,outside) noramdom-seq nailed
failover timeout -1
for 8.2.2 and later configure tcp state bypass
Yudong Wu Tue, 08/03/2010 - 15:05
PIX 6.3 does not support U-turn traffic, you can not send the packet out on the same interface where it is received.
You have to upgrade to code to 7.x first.
