create CNF files with hostnames rather than IPs
Aug 2nd, 2010
I would like to use hostnames rather than IPs in the phone config XML files on my UC520.  The purpose would be so that both private and public IP CME SCCP client phones can load the config files from the same TFTP server rather than having to setup two TFTP servers with different sets of IPs stored in the files.  The CME box that hosts the files will have a private and public IP (via NAT) that resolves to the hostname stored in the files.
Is there somewhere in the config I can set this hostname so the files are created with the hostname when I run the create CNF files command?
Diego
