Telnet from Source??
abhi-adte
I want to know can I telnet from R3-loopback interface to PC1 Router.
like we are use ping 10.1.1.1 source 1.1.1.1 then ping is ok.
same thing I want to know telnet to 10.1.1.1 but source from 1.1.1.1 how I can??
4 Accepted Solutions
Yudong Wu
Level 7
Level 7
ip telnet source-interface
Jayakrishna Mada
telnet 10.1.1.1 /source-interface loopback x
JayaKrishna
Nagaraja Thanthry
Router#telnet
for example:
Router#telnet 10.1.1.1 /source-interface loopback 0
Hope this helps.
NT
As the previous posts show there are 2 ways that you can specify the address to be used for telnet from an IOS device. If you want that the telenet source address will always be the specified address then you should use the configuration option of:
and if you want that the telnet source address be controlled only for this telnet then you should use the command line option of:
So the way to do it depends on whether you want a permanent change or control just for a particular telnet session.
Rick
Rick
Yudong Wu
Level 7
Level 7
Jayakrishna Mada
JayaKrishna
Nagaraja Thanthry
Router#telnet
for example:
Hope this helps.
NT
Rick
Rick
