Call handling for groups where members change during the workday
Answered Question
Aug 2nd, 2010
We are doing a UC560 deployment when an organization would like to have calls routed by the auto attendant to sales, support and the operator.  We are also attempting to follow the Cisco requirement that only CCA or CUE be used for configuration (no CLI).
This is a small organization (less than 20) and the responsible party for answering those calls changes during the workday.
A Blast Group is not appropriate because that would ring every phone that belongs to the group on every call.
The BACD does not support login and logoff of members, so it presents the same issue as a Blast Group in that parties not currently responsible for the group calls end up having their phone ring on every incoming call to the group.
We can create a single shared line for each group, but this limits the number of calls that can be handled before going to voice mail to one because dual line buttons reserve one line for calling out.  Octo line buttons can only be placed on the first button and this also has to be the user's primary extension, so unless a Blast Groups or BACD delivers a call to the primary extension, you can't take advantage of the octo-line capability.
We can create multiple shared lines for each group and then cascade CFB to succesive shared lines in a group and CFNA to a voice mail only extension.  The last shared line wouild also CFB to the same voice mail only extension.  The drawback here is that to handle up to four calls per group would require 12 buttons on an individual's phone that has responsibility for each group at one time or another.
The overlay button seems to address most of the issues above.  If we make one of the overlaid call appearances the voice mail only extension, the button icon can also act as a message waiting indicator.
However, CCA appears to only allow existing shared lines to be included in an overlay,  That means the individual 12 shared line buttons must exist on some phone (or spread across phones) before they can be added to an overlay.  Removing the individual line buttons after the overlay is created invalidates the overlay when trying to save the CCA Configure->Telephony->Voice dialog box changes.
In summary, two questions:
1. Is there a way to create shared line appearances that can be included in an overlay without first assigning them to individual buttoms?
2. Is there a better way to handle incoming calls to "group" extensions where there is a need to handle multiple calls to the group at the same time?
P.S. We are aware that we could assign a separate normal line button to each member of a group and use a blast group to ring all members at the same time.  This gets around the proliferation of shared lines, but all of these blast group members will ring on incoming calls. We could use a solution posted on this site for silent rings using a silent.raw ring tone, but that configuration is overwritten when a UC500 is updated with a new software pack.  This also requires CLI to get the ringtone and XML control files to the UC500 and the appropriate alias registered.
Correct Answer by Steven DiStefano about 6 years 7 months ago
In CCA 2.2.5 (releasing in 2 weeks time), the HLog function has been
added so hunt groups members can log out/log in (covers BACD too).
Perhaps this alone handles your requirement?
I have built shared overlay lines with CCA on CCA 2.2.4 where I
assigned them in cascading fashion to handle max calls and as you have
mentioned you need buttons for the first phone to handle all the
shares (in your case 4x4), but why not place these on a couple 7970s
that don't exist (cipc has 8 buttons), or a single real phone with a
side car?
Steve DiStefano
Technology Solutions Architect - Sales
Cisco Systems
Research Triangle Park
North Carolina, U.S.A
1.919.392.6219
www.cisco.com/smb
On Aug 3, 2010, at 1:50 AM, "lawrence.david"
Overall Rating: 5 (1 ratings)
Correct Answer
Steven DiStefano Tue, 08/03/2010 - 04:02
  • Blue, 1500 points or more
side car?
Steve DiStefano
Cisco Systems
1.919.392.6219
www.cisco.com/smb
lawrence.david Tue, 08/03/2010 - 16:21
Steven,
The Hlog will be a big win for call appearances that benefit from queueing incoming calls.  For example, a support line seems to be a good candidate to me.  Any chance of an early release so we could use it for this deployment?
I created a fake 7975 IP Phone since we are using these on this deployment.  I just made up a MAC address (1111.2222.3333).  I then created shared lines for the number of simultaneous calls I wanted to be able to accept for that "group" or purpose.  From the individual shared lines, I set CFB to the next shared line in the set.  I set CFNA for each shared line to voice mail for the last shared line in the set (6xxx since I have enabled the direct transfer to voicemail with a prefix code in front of the extension).
All that works, but users need to be added to the group representing the General Delivery Mail box created for the extension storing messages for the group.  I did that in CUE.
The only drawback I've noticed so far is that the fake phone appears to consume a user license for the primary extension.  I'd also guess there is a finite number of extensions available.
Dave
