3750 Connectivity issue
I have a WS-C2960G-24TC-L
with a 1000base LX SFP
connected via single mode to an Incomming gigabit circuit from SSE/Telco (Scottish and Southern Electric)
this configuration works ok.
When i move the connection to a WS-C3750G-24TS-1U (with the same sfp) i get no connectivity, no physical or anything,
has anyone seen this before when i do a show interface it does nothing, not connected etc.
Any top tips and handy hots would be appreciated
Keith
Overall Rating: 5 (1 ratings)
Nagaraja Thanthry Tue, 08/03/2010 - 06:21
  • Cisco Employee,
Can you post the output of "show interface " from both
switches with the SFP in the slot?
NT
sh int gi0/22
GigabitEthernet0/22 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0023.052b.a096 (bia 0023.052b.a096)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:09, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 108000 bits/sec, 64 packets/sec
     112643 packets input, 51674930 bytes, 0 no buffer
     Received 54673 broadcasts (0 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 54638 multicast, 0 pause input
     56007230 packets output, 26626201288 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
sh int gi1/0/25
GigabitEthernet1/0/25 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 2893.fe02.5119 (bia 2893.fe02.5119)
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseLX SFP
  Last input 21:19:20, output 21:19:20, output hang never
     21 packets input, 2890 bytes, 0 no buffer
     Received 21 broadcasts (0 multicasts)
     0 watchdog, 21 multicast, 0 pause input
     22 packets output, 3480 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Leo Laohoo Tue, 08/03/2010 - 17:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
And this is the same on all 4 SFP ports of the 3750?
Nagaraja Thanthry Tue, 08/03/2010 - 19:28
  • Cisco Employee,
Are you using the same SFP on both switches i.e. are you moving the SFP from the 2960 to 3750? If not, can you please try that. It could be a bad SFP issue. Also, if you are going via a patch panel for 3750, can you try bypassing the patch panel and see if that helps?
NT
tprendergast Wed, 08/04/2010 - 15:29
  • Silver, 250 points or more
Can you give us the make/model of the SFP?
Also, provide "show run int gi1/0/25" from the 3750, and "show run int gi0/22" of the 2960. Also provide "show ver" for both switches.
Tim
interface GigabitEthernet1/0/25
switchport mode trunk
end
interface GigabitEthernet0/22
end
#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
HC-HQ01-63 uptime is 35 weeks, 3 days, 20 hours, 30 minutes
System restarted at 13:21:43 UTC Sun Nov 29 2009
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision E0) with 61440K/4088K bytes of memory.
Processor board ID FOC1233Y6P8
Last reset from power-on
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:23:05:2B:A0:80
Motherboard assembly number     : 73-10015-06
Power supply part number        : 341-0098-02
Motherboard serial number       : FOC12335ZJ3
Power supply serial number      : AZS1230150B
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C2960G-24TC-L
System serial number            : FOC1233Y6P8
Top Assembly Part Number        : 800-26673-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COM3G00BRB
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   24     WS-C2960G-24TC-L   12.2(35)SE5             C2960-LANBASE-M
Configuration register is 0xF
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01280000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
HC-INV10-01 uptime is 2 weeks, 1 day, 17 hours, 55 minutes
System image file is "flash:c3750-ipservices-mz.122-35.SE5/c3750-ipservices-mz.122-35.SE5.bin"
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision F0) with 118784K/12280K bytes of memory.
Processor board ID FOC1412Y4DD
4 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 28:93:FE:02:51:00
Motherboard assembly number     : 73-10219-07
Motherboard serial number       : FOC14114ZRC
Power supply serial number      : AZS14080139
Model revision number           : F0
Motherboard revision number     : F0
Model number                    : WS-C3750G-24TS-E1U
System serial number            : FOC1412Y4DD
Top Assembly Part Number        : 800-27484-01
Top Assembly Revision Number    : F0
Version ID                      : V03
CLEI Code Number                : CNMWZ00ARC
Hardware Board Revision Number  : 0x09
*    1   28     WS-C3750G-24TS-1U  12.2(35)SE5             C3750-IPSERVICES-M
     2   28     WS-C3750G-24TS-1U  12.2(35)SE5             C3750-IPSERVICES-M
Switch 02
Switch Uptime                   : 2 weeks, 1 day, 17 hours, 54 minutes
Base ethernet MAC Address       : FC:FB:FB:6D:EC:80
Motherboard serial number       : FOC14124W74
Power supply serial number      : AZS141217YZ
System serial number            : FOC1412Y4HA
Top assembly part number        : 800-27484-01
Top assembly revision number    : F0
Version ID                      : V03
SFP model
GLC-LH-SM
Keith
Related Content
