08-03-2010 05:27 AM - edited 03-16-2019 12:03 AM
hello
my costumer have a problem to set up conference between 3 people and more and move out himself
becuse he disconnect the conference .
under service parameter in the ccm i configure " never" disconnect the call
the way that he move out himself from the conference is by hang up the phone or when he press the conference button and than hang up
thanks
Solved! Go to Solution.
08-03-2010 06:34 AM
Your config should do the trick, have you tried resetting the IPVMS?
If he waits until he's in the conference and then he drops does this still happen?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-03-2010 06:34 AM
java
08-03-2010 06:46 AM
hay ,
yes , after 3 of us join the conference and he hang up the phone the conference disconnect
do we have any bugs in this ccm version maybe?
thanks
shoham
08-03-2010 06:48 AM
yes , allready reset the service..........
08-04-2010 12:36 AM
i need your help here......
anything alse?
thanks
shoham
