Cisco ASA 5510 hangs once a month
Aug 3rd, 2010
I've got a question.
Our Cisco ASA hangs once a month with ssl vpn. It loads the login screen but that's it.I can't login or what so ever..
When I restart the ASA everythings works fine.
Has anyone here experienced this problem also? I have no idea where to look for this problem..
Geert Reijnders
Todd Pula Tue, 08/03/2010 - 07:07
This is more than likely related to a memory leak. What version of ASA code are you currently running?  You may want to disable WebVPN caching as a first step and then monitor the memory utilization on the appliance.  If the issue persists, we will need to enable some memory tracking features in order to isolate further.
R1-ASA5505-01# conf t
R1-ASA5505-01(config)# webvpn
R1-ASA5505-01(config-webvpn)# cache
R1-ASA5505-01(config-webvpn-cache)# disable
Geert Reijnders Tue, 08/03/2010 - 07:31
Thanks for quick reply.
I just disabled the cache for the webvpn. Hopefully this will help. I will update this as I know something more.
As you can see, the memory usage is pretty high...
SSL-Firewall# sh mem
Free memory:       104391152 bytes (39%)
Used memory:       164044304 bytes (61%)
Total memory:      268435456 bytes (100%)
Related Content
