Jon Marshall Tue, 08/03/2010 - 08:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The configuration documents for the specific switch will show you how to do this. What is the switch model you are using ?
Jon
Sebastian Helmer Tue, 08/03/2010 - 08:25
  • Silver, 250 points or more
Hey,
first privat vlans are only possible in vtp mode transparent.
- create a primary vlan (vlan A; private-vlan primary)
- Optional you can create a isolated or community vlan and associate it with the primary (vlan B ;private-vlan isolated or private-vlan        community;Enter primary vlan config mode and use private-vlan association [addremove] secondary_vlan_list)
To verify use:
show vlan private-vlan [type]
or
show interfaces status
please look here to find the neccesarry commands in detail for 3750:
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/swpvlan.html#wp1038781
