Command Authentication within ACS 5.1
Answered Question
Aug 3rd, 2010
I have set up a new ACS 5.1 appliance and it seems to be going well.  I would like to be able to restrict access to the command SHOW CDP NEIGHBOR DETAIL to a specific group but continue to allow SHOW CDP NEIGHBOR.
I am able to either allow access to the SHOW CDP commands or deny them but am unable to get more granular with the command arguments.
Can anyone offer any suggestions?
Thanks for the assistance.
Paul Blake
Correct Answer by Przemyslaw Konitz about 6 years 7 months ago
this is my example which works fine
and the result
so it can be done
Overall Rating: 5 (1 ratings)
Correct Answer
Przemyslaw Konitz Tue, 08/10/2010 - 05:27
and the result
so it can be done
p-blake Fri, 08/13/2010 - 11:06
That worked GREAT!!!  Thanks..  I think I was missing the final "s" when inputting the command into the ACS.  Show CDP Neighbor detail is different than show CDP neighbors detail.
Thanks again for you help.
Cisco SCC Tue, 08/17/2010 - 04:14
I have configured ACS 5.1 and im having issues with Commadn sets. Im trying to deny show cdp neighbors to some users. What priv level should they receive when they log in. I just cant get the command sets to deny any commands
Przemyslaw Konitz Tue, 08/17/2010 - 04:21
I would do it in a different way.
create separate rule with additional condition of that separate user group and then as result assign them different command set.
I think its the easiest way
regards
Related Content
