backup-rserver issues
Aug 3rd, 2010
I have configured a serverfarm with two servers that are required by license to be active-passive:
probe http rush1
  interval 10
  faildetect 1
  passdetect interval 5
  passdetect count 1
  receive 5
  request method get url /mrush?operation=ding
  expect status 200 200
  open 5
  expect regex dong
serverfarm host rush
  probe rush1
  rserver rush1
    backup-rserver rush2
    inservice
  rserver rush2
    inservice standby
rserver host rush1
  description RUSH server
  ip address 192.168.0.101
  probe rush1
  inservice
rserver host rush2
  description Backup RUSH server
  ip address 192.168.0.102
  inservice
however, regardless of how I fail over, the second server never leaves 'standby' and does not respond to requests... the counters on the serverfarm go up, including the failuers, on the backup rserver
serverfarm     : rush, type: HOST
total rservers : 2
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: rush1
       192.168.0.101:0          8      PROBE-FAILED 0          1361       25
   rserver: rush2
       192.168.0.102:0          8      STANDBY      0          0          12
yushimaz Mon, 08/09/2010 - 02:01
  • Cisco Employee,
This looks strange behavior. I suspect a bug but have not found similar one.
In my lab, rserver state goes OPERATIONAL from STANDBY when primary
server goes PROBE-FAILED. (This is expected behavior.)
Did you configure as following step only? If not, could you please let me know
your config step? (For example, configure rserver rush1 and rush2 in serververm
and then change configuration with backup-rserver command.)
1) configure probe
2) configure rserver rush1 and rush2
3) configure backup-rserver rush2 in serverfarm (not configure rserver rush2 by hand)
If you use these 2 rservers on other serverfarm,
And also, could you please let me know the ACE version and the number of
'active rservers' in 'show serverfarm detail'?
ACE20/Admin# show ver | i image
  system image file: [LCP] disk0:c6ace-t1k9-mz.A2_3_1.bin
ACE20/Admin#
ACE20/Admin# show serverfarm detail
serverfarm     : sf, type: HOST
total rservers : 2
active rservers: 1  <<==
description    : -
state          : ACTIVE
When primary server goes down (PROBE-FAILED), does only 'failures' counter of
rush2 increase?
   rserver: rush1
   rserver: rush2
       192.168.0.102:0          8      STANDBY      0          0          12  <<== increase this counter?
Yuji
