Upgrade IOS and ROMMON Cat4500
Aug 3rd, 2010
I uploaded my IOS version with supervisory 6-E, version 12.2 (40) SG to a version 12.2 (53) SG2.
From what I read in the release, should also upgrade rommon version 12.2 (40r) SG1 to 12.2 (44r) SG5. In this case I don't because I have not found where is  the ROMMON version.
Can I have a problem with version 12.2 (53) SG2 and ROMMON version 12.2 (40r) SG1?
Here I attached the show ver and dir all where the file is not ROMMON version.
CAT_4510#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 20:14 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11D86AF8
ROM: 12.2(40r)SG1
Darkside Revision 4, Jawa Revision 14, Tatooine Revision 140, Forerunner Revision 1.71
CAT_4510_CP0 uptime is 5 weeks, 2 days, 16 hours, 16 minutes
Uptime for this control processor is 5 weeks, 2 days, 16 hours, 16 minutes
System image file is "bootflash:cat4500e-ipbasek9-mz.122-40.SG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4510R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID SPE114301SX
MPC8548 CPU at 1.33GHz, Supervisor 6-E
Last reset from PowerUp
35 Virtual Ethernet interfaces
256 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
CAT_4510#dir all
Directory of bootflash:/
    6  -rw-    18018580   Feb 5 2008 23:43:22 +01:00  cat4500e-ipbasek9-mz.122-40.SG.bin
131436544 bytes total (108056576 bytes free)
Directory of system:/
    3  dr-x           0                    <no date>  memory
    1  -rw-       46247                    <no date>  running-config
    2  dr-x           0                    <no date>  vfiles
No space information available
Directory of tmpsys:/
    6  drw-           0                    <no date>  eem_lib_system
    5  drw-           0                    <no date>  eem_lib_user
    4  drw-           0                    <no date>  eem_policy
    1  dr-x           0                    <no date>  lib
Directory of nvram:/
  500  -rw-       11091                    <no date>  startup-config
  501  ----           5                    <no date>  private-config
    1  ----          47                    <no date>  persistent-data
    2  -rw-           0                    <no date>  ifIndex-table.gz
524284 bytes total (511088 bytes free)
Directory of crashinfo:/
    1  -r--         140                    <no date>  data
    2  -r--           0                    <no date>  data.bin
Directory of cat4000_flash:/
    1  -rw-        2844                    <no date>  vlan.dat
524284 bytes total (521440 bytes free)
Directory of profiler:/
    1  -r--           0                    <no date>  data
Reza Sharifi Tue, 08/03/2010 - 08:13
You should be fine with the current version you have.  You don't have to have always the latest ROMMON version.
Jayakrishna Mada Tue, 08/03/2010 - 08:19
Hi ,
I see that you are still running 122-40.SG. I dont see that you have upgraded the switch to 12.2 (53) SG2.
In the release notes for sup6e the minimum and recommended ROMMON version is 12.2(44r)SG5 so I would definetely upgrade that as well.
These are the defects that you might run into with the currrent rommon version:
CSCsu05453, CSCsu36751 and CSCsu73446
You can find the ROMMON version here:
slandeira Tue, 08/03/2010 - 08:31
This show ver is before doing the upgrade.
My question is where is save the previous version and where i will copy the new version? I do not see the file anywhere.
In the release notes the file  is in the bootflash, but in my case there does not appear.
Thank you very much.
Jayakrishna Mada Tue, 08/03/2010 - 08:35
You need to download the IOS version (12.2 (53) SG2) and ROMMON version from the Cisco website to your PC and upload them to the switch bootflash on the switch and follow the procedure to upgrade the ROMMON and IOS version.
Already running version is here and you will download the new version and rommon version here.
Related Content
