rvs4000
Aug 3rd, 2010
Dear Sirs,
     We have a problem with rvs4000... we need to do a simple VPN using QuickVPN software but every time we try to connect we obtain the same error message: the remote gateway is not responding. do you want to wait?
... log of Quickvpn is:
2010/08/03 16:50:26 [STATUS]Success to disconnect.
2010/08/03 16:59:34 [STATUS]OS Version: Windows Vista
2010/08/03 16:59:34 [STATUS]Windows Firewall Domain Profile Settings: ON
2010/08/03 16:59:34 [STATUS]Windows Firewall Private Profile Settings: OFF
2010/08/03 16:59:35 [STATUS]One network interface detected with IP address 192.168.1.33
2010/08/03 16:59:35 [STATUS]Connecting...
2010/08/03 16:59:35 [DEBUG]Input VPN Server Address = 88.xxx.xxx.xxx
2010/08/03 16:59:35 [STATUS]Connecting to remote gateway with IP address: 88.xxx.xxx.xxx
2010/08/03 16:59:45 [WARNING]Remote gateway wasn't reached...
2010/08/03 16:59:45 [WARNING]Failed to connect.
2010/08/03 16:59:49 [STATUS]Remote gateway was reached by https ...
2010/08/03 16:59:49 [STATUS]Provisioning...
2010/08/03 16:59:58 [STATUS]Success to connect.
2010/08/03 16:59:58 [STATUS]Tunnel is configured. Ping test is about to start.
2010/08/03 16:59:58 [STATUS]Verifying Network...
2010/08/03 17:00:04 [WARNING]Failed to ping remote VPN Router!
2010/08/03 17:00:07 [WARNING]Failed to ping remote VPN Router!
2010/08/03 17:00:10 [WARNING]Failed to ping remote VPN Router!
2010/08/03 17:00:13 [WARNING]Failed to ping remote VPN Router!
2010/08/03 17:00:16 [WARNING]Failed to ping remote VPN Router!
2010/08/03 17:00:29 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
We only want to do this simple vpn
(internal work lan 10.1.1.x)---(10.1.1.254/RVS4000/88.xxx.xxx.xxx)------internet----(dsl connection with dinamic ip)--- (myhomepc 192.168.1.33)
we try a lot of way without result: we think that it isn't a problem of internet firewall because we also connect a pc for simulate internet on 88.x.x.x.x range... no result...
all vpn passthrought are enabled...
Someone can help us?
With regards
Roberto & Daniele
qsecofr76 Fri, 08/06/2010 - 09:18
auto-resolved... it seems that quickvpn don't want 2 different ip local address on client pc...
