MLPPP and MFR in the same router
Aug 3rd, 2010
Is it possible to run both MLFR and MLPPP within the same router?
For example both the first 2 T1s using MLFR with carrier A and the second 2 T1s using MLPPP with another Carrier B?
Overall Rating: 5 (1 ratings)
vmiller Tue, 08/03/2010 - 08:44
Same Router should be no problem. You just need two physical interfaces (serial)
Related Content
