WAE module GUI TCP statistics
larry.scrivner
Is there a way withing the WAE module GUI to view TCP connections?
If not is there anyway to view stats without logging into the CM?
smnambia
You can view the tcp connection statistics either from the CM or the individual wae device cli.
You can't view the tcp connection statistics from the individual wae device gui.
For the device cli if running WAAS version 4.1.x and aboive the command is sh statistics connection.
Following command reference will give you all the options available for the above command
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v421/command/reference/execmds.html#wp2487527
If running WAAS version 4.0.x the command is sh tfo connection summary
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4019/command/reference/execmds.html#wp1051632
-Smita Nambiar
Is there a way to poll this information using MIBS and SNMP traps and creating our own "GUI" and creating some sort of Histo-graph?
