How do I open ports on ASA 5505?
Aug 3rd, 2010
I am new to the Cisco model so excuse my lack of wisdom with this product.  I work for a small rural Hospital and we need to FTP a report once a month to a clearing house.  Problem is I can't FTP their site, I can others but not theres.  I was told that it was because I didn't have the correct ports open for their transmission.  I was told that I needed 20,21,22 (possibly) and all ports above 1023 available.  I thought I had that setup through my ASDM configuration but I still can't get connected.  If I try to trace the packet it works fine on the inside test but if I run it from outside it always goes back to the implicit rule to block IP.  What am I missing?  I can provide screen shots of what ever is needed.  I know the site works as I was able to connect to it from my home last night.
Thanks for your help!
Rahul Govindan Tue, 08/03/2010 - 09:35
hi are you using passive or active ftp. From what i understand, you have the hosts on the inside and the ftp server on the outside. Try issuing the command fixup protocol ftp 21 on the command line of the ASA an test the connection if possible. You could provide the config if that does not work.
pershingit Tue, 08/03/2010 - 12:02
Passive, yes have a workstation on the inside of my ASA that needs to ftp to a server on the outside to transmit.  I can transmit to our web server via ftp without issue but this particular site has more structure so when it's trying to reply back it's traffic is being blocked.  Hope that makes sense.
Allen P Chen Tue, 08/03/2010 - 10:12
In looking at the packet tracer screenshot, I believe the parameters are incorrect.  You are trying to get a host behind the inside interface of the ASA to access a host on the outside via FTP, correct?  If so, the source interface should be in the inside interface, not the outside interface.  Also, the source port should be a random port about 1024, with the destination port at 21.
Please give that a try and provide the packet tracer output.
pershingit Tue, 08/03/2010 - 12:08
Ok knowing it is a passive connection how does that change things?
Thanks!
Nagaraja Thanthry Tue, 08/03/2010 - 13:10
If it is passive, I don't see any reason why it should not be working. Can
you please put captures on the firewall and see what is happening when you
establish the FTP session?
access-list cap permit ip any host any
capture capin access-list cap interface inside
capture capout access-list cap interface outside
once these lines are put into the firewall, establish a FTP session. Once it
fails, collect the outputs:
show capture capin
show capture capout
Please post those outputs here so we can try to identify the root cause.
NT
Magnus Mortensen Tue, 08/03/2010 - 14:13
Scott, can you please post the output of "show service-policy" from the ASA. I want to see how the inspections are configured. The FTP inspection should kick in here unless it is something like sFTP (encrypted).   - Magnus
pershingit Wed, 08/04/2010 - 07:26
How do I go about doing that, I am very new to the ASA/Cisco world.
Thanks!
Nagaraja Thanthry Wed, 08/04/2010 - 18:24
If you are using command line, then you can copy the commands as it is. If you are using ASDM, then you cna go to tools --> command line --> multiple lines and paste all the commands I had mentioned and then run the test.
Hope this helps.
NT
pershingit Fri, 08/06/2010 - 06:43
NT
I followed your directions and here is the list you asked for.
217 packets captured
1: 07:33:40.806720 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2981: P 1201258463:1201258868(405) ack 2466803114 win 8192
2: 07:33:40.938336 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539176805:2539178018(1213) ack 9461028 win 8192
3: 07:33:41.047696 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2981: P 1201258868:1201258905(37) ack 2466803114 win 8192
4: 07:33:41.048200 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2981: F 1201258905:1201258905(0) ack 2466803151 win 8192
5: 07:33:41.048322 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2981: . ack 2466803152 win 8192
6: 07:33:41.157065 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539178018:2539178199(181) ack 9461028 win 8192
7: 07:33:41.572556 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539178199:2539178380(181) ack 9461028 win 8192
8: 07:33:41.933469 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539178380:2539178529(149) ack 9461028 win 8192
9: 07:33:42.141395 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539178529:2539178907(378) ack 9461028 win 8192
10: 07:33:42.559739 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539178907:2539179056(149) ack 9461028 win 8192
11: 07:33:42.670772 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539179056:2539180316(1260) ack 9461028 win 8192
12: 07:33:42.671489 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539180316:2539180637(321) ack 9461028 win 8192
13: 07:33:42.797520 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539180637:2539180983(346) ack 9461028 win 8192
14: 07:33:43.016341 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539180983:2539181164(181) ack 9461028 win 8192
15: 07:33:43.242144 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539181164:2539181345(181) ack 9461028 win 8192
16: 07:33:44.790074 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539181345:2539181526(181) ack 9461028 win 8192
17: 07:33:45.263597 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539181526:2539181707(181) ack 9461028 win 8192
18: 07:33:45.665340 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539181707:2539181856(149) ack 9461028 win 8192
19: 07:33:45.859849 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539181856:2539182926(1070) ack 9461028 win 8192
20: 07:33:46.078807 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539182926:2539183304(378) ack 9461028 win 8192
21: 07:33:46.297271 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539183304:2539183666(362) ack 9461028 win 8192
22: 07:33:47.130120 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539816182:3539817442(1260) ack 248762417 win 8192
23: 07:33:47.130181 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539817442:3539818702(1260) ack 248762417 win 8192
24: 07:33:47.131462 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539818702:3539819707(1005) ack 248762417 win 8192
25: 07:33:47.679545 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539183666:2539183847(181) ack 9461028 win 8192
26: 07:33:47.828372 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539183847:2539184028(181) ack 9461028 win 8192
27: 07:33:48.117959 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539184028:2539184209(181) ack 9461028 win 8192
28: 07:33:48.265916 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539184209:2539184390(181) ack 9461028 win 8192
29: 07:33:48.825564 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539184390:2539184587(197) ack 9461028 win 8192
30: 07:33:49.031492 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539184587:2539184949(362) ack 9461028 win 8192
31: 07:33:50.205174 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
32: 07:33:50.205342 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539184949:2539185098(149) ack 9461028 win 8192
33: 07:33:52.075237 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185098:2539185279(181) ack 9461028 win 8192
34: 07:33:52.306258 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185279:2539185460(181) ack 9461028 win 8192
35: 07:33:52.444267 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185460:2539185641(181) ack 9461028 win 8192
36: 07:33:53.819995 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185641:2539185822(181) ack 9461028 win 8192
37: 07:33:54.295272 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185822:2539185971(149) ack 9461028 win 8192
38: 07:33:54.499958 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539185971:2539186695(724) ack 9461028 win 8192
39: 07:33:54.718621 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539186695:2539187057(362) ack 9461028 win 8192
40: 07:33:54.937314 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539187057:2539187238(181) ack 9461028 win 8192
41: 07:33:55.380305 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539187238:2539187419(181) ack 9461028 win 8192
42: 07:33:55.921842 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539187419:2539187568(149) ack 9461028 win 8192
43: 07:33:56.140465 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539187568:2539188324(756) ack 9461028 win 8192
44: 07:33:56.359173 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539188324:2539188505(181) ack 9461028 win 8192
45: 07:33:57.130318 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539819707:3539820967(1260) ack 248762417 win 8192
46: 07:33:57.130379 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539820967:3539822227(1260) ack 248762417 win 8192
47: 07:33:57.131295 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539822227:3539823216(989) ack 248762417 win 8192
48: 07:33:57.494298 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539188505:2539188686(181) ack 9461028 win 8192
49: 07:33:57.593887 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
50: 07:33:57.671580 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539188686:2539188835(149) ack 9461028 win 8192
51: 07:33:57.890319 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539188835:2539189016(181) ack 9461028 win 8192
52: 07:33:58.366756 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539189016:2539189197(181) ack 9461028 win 8192
53: 07:33:58.546480 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539189197:2539189378(181) ack 9461028 win 8192
54: 07:33:58.765249 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539189378:2539190102(724) ack 9461028 win 8192
55: 07:33:59.108713 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539190102:2539190283(181) ack 9461028 win 8192
56: 07:33:59.312117 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539190283:2539190464(181) ack 9461028 win 8192
57: 07:33:59.530856 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539190464:2539190645(181) ack 9461028 win 8192
58: 07:34:00.113778 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539190645:2539190826(181) ack 9461028 win 8192
59: 07:34:00.296401 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539190826:2539191023(197) ack 9461028 win 8192
60: 07:34:01.436958 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191023:2539191204(181) ack 9461028 win 8192
61: 07:34:01.873123 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191204:2539191385(181) ack 9461028 win 8192
62: 07:34:02.208698 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191385:2539191566(181) ack 9461028 win 8192
63: 07:34:02.963741 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191566:2539191747(181) ack 9461028 win 8192
64: 07:34:03.450248 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191747:2539191928(181) ack 9461028 win 8192
65: 07:34:03.601195 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539191928:2539192109(181) ack 9461028 win 8192
66: 07:34:03.796192 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539192109:2539192471(362) ack 9461028 win 8192
67: 07:34:04.738349 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539192471:2539192620(149) ack 9461028 win 8192
68: 07:34:04.889877 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539192620:2539193344(724) ack 9461028 win 8192
69: 07:34:05.631284 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539193344:2539193525(181) ack 9461028 win 8192
70: 07:34:06.046979 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539193525:2539193674(149) ack 9461028 win 8192
71: 07:34:06.202305 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539193674:2539194052(378) ack 9461028 win 8192
72: 07:34:06.755332 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194052:2539194233(181) ack 9461028 win 8192
73: 07:34:07.130410 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539823216:3539824476(1260) ack 248762417 win 8192
74: 07:34:07.130471 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539824476:3539825736(1260) ack 248762417 win 8192
75: 07:34:07.132027 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539825736:3539826725(989) ack 248762417 win 8192
76: 07:34:07.174826 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194233:2539194414(181) ack 9461028 win 8192
77: 07:34:07.338773 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194414:2539194595(181) ack 9461028 win 8192
78: 07:34:07.610991 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194595:2539194776(181) ack 9461028 win 8192
79: 07:34:08.349270 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194776:2539194957(181) ack 9461028 win 8192
80: 07:34:08.734977 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539194957:2539195154(197) ack 9461028 win 8192
81: 07:34:08.943722 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
82: 07:34:08.943844 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539195154:2539195303(149) ack 9461028 win 8192
83: 07:34:09.155219 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539195303:2539195500(197) ack 9461028 win 8192
84: 07:34:09.657894 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539195500:2539195681(181) ack 9461028 win 8192
85: 07:34:10.127648 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539195681:2539195862(181) ack 9461028 win 8192
86: 07:34:10.248903 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539195862:2539196059(197) ack 9461028 win 8192
87: 07:34:10.467627 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539196059:2539196208(149) ack 9461028 win 8192
88: 07:34:10.551302 802.1Q vlan#1 P0 10.10.2.216 > 10.10.2.125: icmp: echo reply
89: 07:34:10.686365 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539196208:2539196357(149) ack 9461028 win 8192
90: 07:34:11.451743 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539196357:2539196506(149) ack 9461028 win 8192
91: 07:34:11.670634 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539196506:2539196884(378) ack 9461028 win 8192
92: 07:34:11.889282 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539196884:2539197230(346) ack 9461028 win 8192
93: 07:34:12.108057 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539197230:2539197773(543) ack 9461028 win 8192
94: 07:34:12.359051 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539197773:2539197954(181) ack 9461028 win 8192
95: 07:34:12.545595 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539197954:2539198268(314) ack 9461028 win 8192
96: 07:34:12.764288 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539198268:2539198960(692) ack 9461028 win 8192
97: 07:34:13.013335 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539198960:2539199141(181) ack 9461028 win 8192
98: 07:34:13.984247 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539199141:2539199290(149) ack 9461028 win 8192
99: 07:34:14.186071 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539199290:2539200014(724) ack 9461028 win 8192
100: 07:34:14.795613 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539200014:2539200211(197) ack 9461028 win 8192
101: 07:34:14.951671 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539200211:2539200392(181) ack 9461028 win 8192
102: 07:34:15.831911 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539200392:2539200573(181) ack 9461028 win 8192
103: 07:34:16.045377 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539200573:2539200754(181) ack 9461028 win 8192
104: 07:34:16.264070 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539200754:2539201100(346) ack 9461028 win 8192
105: 07:34:16.482839 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539201100:2539201462(362) ack 9461028 win 8192
106: 07:34:17.130608 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539826725:3539827985(1260) ack 248762417 win 8192
107: 07:34:17.130669 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539827985:3539829245(1260) ack 248762417 win 8192
108: 07:34:17.131829 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539829245:3539830250(1005) ack 248762417 win 8192
109: 07:34:18.315016 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539201462:2539201643(181) ack 9461028 win 8192
110: 07:34:18.439918 802.1Q vlan#1 P0 10.10.2.254 > 10.10.2.125: icmp: echo reply
111: 07:34:18.439964 802.1Q vlan#1 P0 10.10.2.254 > 10.10.2.125: icmp: echo reply
112: 07:34:18.440147 802.1Q vlan#1 P0 10.10.2.254 > 10.10.2.125: icmp: echo reply
113: 07:34:18.451377 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539201643:2539201941(298) ack 9461028 win 8192
114: 07:34:20.671260 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539201941:2539202090(149) ack 9461028 win 8192
115: 07:34:20.857545 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539202090:2539202287(197) ack 9461028 win 8192
116: 07:34:21.101404 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539202287:2539202484(197) ack 9461028 win 8192
117: 07:34:21.295043 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539202484:2539202681(197) ack 9461028 win 8192
118: 07:34:21.513675 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539202681:2539203027(346) ack 9461028 win 8192
119: 07:34:21.754309 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203027:2539203208(181) ack 9461028 win 8192
120: 07:34:22.111169 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203208:2539203405(197) ack 9461028 win 8192
121: 07:34:24.246706 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203405:2539203602(197) ack 9461028 win 8192
122: 07:34:24.357327 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203602:2539203783(181) ack 9461028 win 8192
123: 07:34:24.576065 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203783:2539203964(181) ack 9461028 win 8192
124: 07:34:24.794728 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539203964:2539204145(181) ack 9461028 win 8192
125: 07:34:25.948650 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539204145:2539204326(181) ack 9461028 win 8192
126: 07:34:26.133187 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539204326:2539204507(181) ack 9461028 win 8192
127: 07:34:26.325926 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539204507:2539204853(346) ack 9461028 win 8192
128: 07:34:26.544664 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539204853:2539205034(181) ack 9461028 win 8192
129: 07:34:26.763372 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539205034:2539205380(346) ack 9461028 win 8192
130: 07:34:27.130715 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539830250:3539831510(1260) ack 248762417 win 8192
131: 07:34:27.130776 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539831510:3539832770(1260) ack 248762417 win 8192
132: 07:34:27.131646 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539832770:3539833775(1005) ack 248762417 win 8192
133: 07:34:28.072490 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539205380:2539205529(149) ack 9461028 win 8192
134: 07:34:28.185201 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539205529:2539206221(692) ack 9461028 win 8192
135: 07:34:28.403909 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539206221:2539206402(181) ack 9461028 win 8192
136: 07:34:28.622541 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539206402:2539206583(181) ack 9461028 win 8192
137: 07:34:28.867875 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539206583:2539206764(181) ack 9461028 win 8192
138: 07:34:29.522250 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539206764:2539206945(181) ack 9461028 win 8192
139: 07:34:29.850450 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
140: 07:34:29.850587 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539206945:2539207094(149) ack 9461028 win 8192
141: 07:34:30.044461 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207094:2539207275(181) ack 9461028 win 8192
142: 07:34:31.089244 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207275:2539207472(197) ack 9461028 win 8192
143: 07:34:31.247500 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207472:2539207669(197) ack 9461028 win 8192
144: 07:34:31.568650 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207669:2539207834(165) ack 9461028 win 8192
145: 07:34:31.684977 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207834:2539207999(165) ack 9461028 win 8192
146: 07:34:32.329710 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539207999:2539208196(197) ack 9461028 win 8192
147: 07:34:32.860947 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539208196:2539208377(181) ack 9461028 win 8192
148: 07:34:32.997308 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539208377:2539208558(181) ack 9461028 win 8192
149: 07:34:33.216099 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539208558:2539208920(362) ack 9461028 win 8192
150: 07:34:33.599181 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539208920:2539209085(165) ack 9461028 win 8192
151: 07:34:33.762915 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539209085:2539209234(149) ack 9461028 win 8192
152: 07:34:34.076885 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539209234:2539209431(197) ack 9461028 win 8192
153: 07:34:34.165869 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
154: 07:34:34.200368 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539209431:2539210320(889) ack 9461028 win 8192
155: 07:34:34.756766 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539210320:2539210501(181) ack 9461028 win 8192
156: 07:34:36.020018 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539210501:2539210650(149) ack 9461028 win 8192
157: 07:34:36.169012 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539210650:2539211028(378) ack 9461028 win 8192
158: 07:34:36.387766 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539211028:2539211225(197) ack 9461028 win 8192
159: 07:34:36.606444 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539211225:2539211752(527) ack 9461028 win 8192
160: 07:34:36.825183 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539211752:2539212098(346) ack 9461028 win 8192
161: 07:34:37.130898 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539833775:3539835035(1260) ack 248762417 win 8192
162: 07:34:37.130959 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539835035:3539836295(1260) ack 248762417 win 8192
163: 07:34:37.132378 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539836295:3539837284(989) ack 248762417 win 8192
164: 07:34:37.480733 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539212098:2539212295(197) ack 9461028 win 8192
165: 07:34:37.700098 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539212295:2539212476(181) ack 9461028 win 8192
166: 07:34:37.918897 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539212476:2539213381(905) ack 9461028 win 8192
167: 07:34:38.137611 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539213381:2539214641(1260) ack 9461028 win 8192
168: 07:34:38.356442 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539214641:2539215633(992) ack 9461028 win 8192
169: 07:34:38.575089 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539215633:2539215963(330) ack 9461028 win 8192
170: 07:34:39.551332 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539215963:2539216144(181) ack 9461028 win 8192
171: 07:34:39.684245 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539216144:2539216293(149) ack 9461028 win 8192
172: 07:34:39.887420 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539216293:2539216490(197) ack 9461028 win 8192
173: 07:34:40.106302 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539216490:2539217033(543) ack 9461028 win 8192
174: 07:34:40.324995 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539217033:2539217214(181) ack 9461028 win 8192
175: 07:34:40.543673 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539217214:2539217874(660) ack 9461028 win 8192
176: 07:34:40.762381 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539217874:2539218055(181) ack 9461028 win 8192
177: 07:34:41.177618 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539218055:2539218204(149) ack 9461028 win 8192
178: 07:34:41.309233 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539218204:2539218401(197) ack 9461028 win 8192
179: 07:34:41.528003 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539218401:2539218976(575) ack 9461028 win 8192
180: 07:34:41.887100 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539218976:2539219157(181) ack 9461028 win 8192
181: 07:34:42.555559 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539219157:2539219306(149) ack 9461028 win 8192
182: 07:34:42.731087 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539219306:2539220557(1251) ack 9461028 win 8192
183: 07:34:42.949810 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539220557:2539220919(362) ack 9461028 win 8192
184: 07:34:43.168600 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539220919:2539221510(591) ack 9461028 win 8192
185: 07:34:43.387278 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539221510:2539222037(527) ack 9461028 win 8192
186: 07:34:43.606047 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539222037:2539222218(181) ack 9461028 win 8192
187: 07:34:44.017897 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539222218:2539222399(181) ack 9461028 win 8192
188: 07:34:44.197758 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539222399:2539222548(149) ack 9461028 win 8192
189: 07:34:44.371547 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539222548:2539223107(559) ack 9461028 win 8192
190: 07:34:44.590301 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539223107:2539223304(197) ack 9461028 win 8192
191: 07:34:45.223636 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539223304:2539223469(165) ack 9461028 win 8192
192: 07:34:45.355953 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539223469:2539223831(362) ack 9461028 win 8192
193: 07:34:45.574585 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539223831:2539224422(591) ack 9461028 win 8192
194: 07:34:45.964030 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539224422:2539224603(181) ack 9461028 win 8192
195: 07:34:46.121423 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539224603:2539224965(362) ack 9461028 win 8192
196: 07:34:46.340222 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539224965:2539225146(181) ack 9461028 win 8192
197: 07:34:46.558931 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539225146:2539225492(346) ack 9461028 win 8192
198: 07:34:46.777669 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539225492:2539226365(873) ack 9461028 win 8192
199: 07:34:46.996393 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539226365:2539227073(708) ack 9461028 win 8192
200: 07:34:47.131020 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539837284:3539838544(1260) ack 248762417 win 8192
201: 07:34:47.131081 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539838544:3539839804(1260) ack 248762417 win 8192
202: 07:34:47.132195 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2926: P 3539839804:3539840809(1005) ack 248762417 win 8192
203: 07:34:47.215122 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539227073:2539227451(378) ack 9461028 win 8192
204: 07:34:47.433891 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539227451:2539228324(873) ack 9461028 win 8192
205: 07:34:47.652523 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539228324:2539228489(165) ack 9461028 win 8192
206: 07:34:47.871369 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539228489:2539229032(543) ack 9461028 win 8192
207: 07:34:48.379985 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539229032:2539229213(181) ack 9461028 win 8192
208: 07:34:48.663417 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539229213:2539229410(197) ack 9461028 win 8192
209: 07:34:49.269379 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539229410:2539229559(149) ack 9461028 win 8192
210: 07:34:49.402521 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539229559:2539230661(1102) ack 9461028 win 8192
211: 07:34:49.671824 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539230661:2539230810(149) ack 9461028 win 8192
212: 07:34:49.839876 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.2924: P 2539230810:2539230975(165) ack 9461028 win 8192
213: 07:34:49.859986 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.3007: S 2946830453:2946830453(0) ack 50794500 win 8192 10.10.2.125.3007: . ack 50795223 win 7963
217 packets shown
Result of the command: "show capture capout"
0 packet captured
0 packet shown
Hope that is what you were wanting to see.
Thanks!
Scott T
pershingit Fri, 08/06/2010 - 07:17
In the copy and paste I did from your previous email on the first line I changed the all statement (it didn't like that) to my personal ip address of 10.10.2.125.
Is that what you are looking for?
Scott
Nagaraja Thanthry Fri, 08/06/2010 - 08:16
I am not sure why I posted that access-list. My apologies. Can you please
change the access-list as below and capture again:
no cap capin
no cap capout
clear configure access-li cap
Once this is done, please rerun the test and post the outputs.
NT
pershingit Fri, 08/06/2010 - 09:54
Here you go hope that helps.
Result of the command: "show capture capin"
253 packets captured
1: 10:45:03.333906 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4383: P 1631152414:1631152547(133) ack 1152984638 win 8192
2: 10:45:03.453727 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4383: P 1631152547:1631152584(37) ack 1152984638 win 8192
3: 10:45:03.454306 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4383: F 1631152584:1631152584(0) ack 1152984675 win 8192
4: 10:45:03.454352 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4383: . ack 1152984676 win 8192
5: 10:45:03.562974 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455493137:455494382(1245) ack 3776373837 win 8192
6: 10:45:03.781804 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455494382:455494728(346) ack 3776373837 win 8192
7: 10:45:04.007522 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455494728:455495436(708) ack 3776373837 win 8192
8: 10:45:04.327848 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455495436:455495633(197) ack 3776373837 win 8192
9: 10:45:04.437935 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455495633:455496506(873) ack 3776373837 win 8192
10: 10:45:04.656658 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455496506:455496852(346) ack 3776373837 win 8192
11: 10:45:04.755835 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455496852:455498112(1260) ack 3776373837 win 8192
12: 10:45:04.756522 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455498112:455498939(827) ack 3776373837 win 8192
13: 10:45:04.984736 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455498939:455499136(197) ack 3776373837 win 8192
14: 10:45:05.203648 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455499136:455500323(1187) ack 3776373837 win 8192
15: 10:45:05.422280 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455500323:455501047(724) ack 3776373837 win 8192
16: 10:45:05.600921 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455501047:455502307(1260) ack 3776373837 win 8192
17: 10:45:05.601607 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455502307:455503567(1260) ack 3776373837 win 8192
18: 10:45:05.609847 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455503567:455504827(1260) ack 3776373837 win 8192
19: 10:45:05.611494 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455504827:455506087(1260) ack 3776373837 win 8192
20: 10:45:05.646527 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455506087:455507347(1260) ack 3776373837 win 8192
21: 10:45:05.647198 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455507347:455508196(849) ack 3776373837 win 8192
22: 10:45:05.677790 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455508196:455509456(1260) ack 3776373837 win 8192
23: 10:45:05.678446 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455509456:455509942(486) ack 3776373837 win 8192
24: 10:45:05.735160 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455509942:455511202(1260) ack 3776373837 win 8192
25: 10:45:05.735817 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455511202:455511342(140) ack 3776373837 win 8192
26: 10:45:05.973902 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455511342:455511688(346) ack 3776373837 win 8192
27: 10:45:06.187841 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455511688:455512822(1134) ack 3776373837 win 8192
28: 10:45:06.298293 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455512822:455514082(1260) ack 3776373837 win 8192
29: 10:45:06.299468 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455514082:455514664(582) ack 3776373837 win 8192
30: 10:45:06.515995 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455514664:455515255(591) ack 3776373837 win 8192
31: 10:45:06.734611 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455515255:455515436(181) ack 3776373837 win 8192
32: 10:45:07.423714 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455515436:455515585(149) ack 3776373837 win 8192
33: 10:45:07.719033 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455515585:455515782(197) ack 3776373837 win 8192
34: 10:45:10.212238 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455515782:455515963(181) ack 3776373837 win 8192
35: 10:45:10.833132 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809428474:2809429734(1260) ack 1108453567 win 8192
36: 10:45:10.833208 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809429734:2809430994(1260) ack 1108453567 win 8192
37: 10:45:10.834307 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809430994:2809431999(1005) ack 1108453567 win 8192
38: 10:45:11.231494 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455515963:455516112(149) ack 3776373837 win 8192
39: 10:45:11.309432 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455516112:455517372(1260) ack 3776373837 win 8192
40: 10:45:11.310622 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455517372:455517624(252) ack 3776373837 win 8192
41: 10:45:11.437446 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455517624:455518151(527) ack 3776373837 win 8192
42: 10:45:11.671763 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455518151:455518332(181) ack 3776373837 win 8192
43: 10:45:11.984293 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455518332:455519056(724) ack 3776373837 win 8192
44: 10:45:12.312560 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455519056:455520316(1260) ack 3776373837 win 8192
45: 10:45:12.531192 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455520316:455520850(534) ack 3776373837 win 8192
46: 10:45:12.765554 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455520850:455521590(740) ack 3776373837 win 8192
47: 10:45:12.968669 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455521590:455522314(724) ack 3776373837 win 8192
48: 10:45:13.187414 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455522314:455523022(708) ack 3776373837 win 8192
49: 10:45:13.515506 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455523022:455523895(873) ack 3776373837 win 8192
50: 10:45:13.843523 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455523895:455524241(346) ack 3776373837 win 8192
51: 10:45:15.983591 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455524241:455524422(181) ack 3776373837 win 8192
52: 10:45:16.249651 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455524422:455524784(362) ack 3776373837 win 8192
53: 10:45:16.468344 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455524784:455524965(181) ack 3776373837 win 8192
54: 10:45:16.687082 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455524965:455525146(181) ack 3776373837 win 8192
55: 10:45:17.158011 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455525146:455525327(181) ack 3776373837 win 8192
56: 10:45:17.452750 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455525327:455525508(181) ack 3776373837 win 8192
57: 10:45:18.114312 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455525508:455525689(181) ack 3776373837 win 8192
58: 10:45:18.327604 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455525689:455525870(181) ack 3776373837 win 8192
59: 10:45:18.558900 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455525870:455526019(149) ack 3776373837 win 8192
60: 10:45:18.765097 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455526019:455526594(575) ack 3776373837 win 8192
61: 10:45:19.093241 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455526594:455527854(1260) ack 3776373837 win 8192
62: 10:45:19.311934 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455527854:455528239(385) ack 3776373837 win 8192
63: 10:45:19.530734 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455528239:455529499(1260) ack 3776373837 win 8192
64: 10:45:19.749381 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455529499:455529836(337) ack 3776373837 win 8192
65: 10:45:20.078441 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455529836:455530182(346) ack 3776373837 win 8192
66: 10:45:20.405618 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455530182:455530544(362) ack 3776373837 win 8192
67: 10:45:20.833269 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809431999:2809433259(1260) ack 1108453567 win 8192
68: 10:45:20.833330 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809433259:2809434519(1260) ack 1108453567 win 8192
69: 10:45:20.834093 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809434519:2809435524(1005) ack 1108453567 win 8192
70: 10:45:20.932843 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455530544:455530725(181) ack 3776373837 win 8192
71: 10:45:21.061825 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455530725:455530906(181) ack 3776373837 win 8192
72: 10:45:21.389643 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455530906:455531103(197) ack 3776373837 win 8192
73: 10:45:21.718071 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455531103:455532253(1150) ack 3776373837 win 8192
74: 10:45:21.936810 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455532253:455532434(181) ack 3776373837 win 8192
75: 10:45:22.264909 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455532434:455532961(527) ack 3776373837 win 8192
76: 10:45:22.608595 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455532961:455533504(543) ack 3776373837 win 8192
77: 10:45:22.811725 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455533504:455534244(740) ack 3776373837 win 8192
78: 10:45:23.139915 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455534244:455534425(181) ack 3776373837 win 8192
79: 10:45:23.579895 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455534425:455534606(181) ack 3776373837 win 8192
80: 10:45:24.055890 802.1Q vlan#1 P0 10.10.2.254.514 > 10.10.2.125.514: udp 126
81: 10:45:24.056042 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455534606:455534755(149) ack 3776373837 win 8192
82: 10:45:24.342893 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455534755:455535628(873) ack 3776373837 win 8192
83: 10:45:24.910597 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455535628:455535825(197) ack 3776373837 win 8192
84: 10:45:25.217853 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455535825:455536171(346) ack 3776373837 win 8192
85: 10:45:25.436607 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455536171:455536533(362) ack 3776373837 win 8192
86: 10:45:25.669765 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455536533:455536895(362) ack 3776373837 win 8192
87: 10:45:25.983378 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455536895:455537076(181) ack 3776373837 win 8192
88: 10:45:26.311507 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455537076:455537257(181) ack 3776373837 win 8192
89: 10:45:26.530276 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455537257:455537454(197) ack 3776373837 win 8192
90: 10:45:26.801121 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455537454:455537635(181) ack 3776373837 win 8192
91: 10:45:27.346844 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455537635:455537832(197) ack 3776373837 win 8192
92: 10:45:27.874878 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455537832:455538013(181) ack 3776373837 win 8192
93: 10:45:28.061382 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455538013:455538194(181) ack 3776373837 win 8192
94: 10:45:28.389521 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455538194:455538886(692) ack 3776373837 win 8192
95: 10:45:28.733253 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455538886:455539067(181) ack 3776373837 win 8192
96: 10:45:29.045682 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455539067:455539807(740) ack 3776373837 win 8192
97: 10:45:29.303725 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455539807:455541067(1260) ack 3776373837 win 8192
98: 10:45:29.304412 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455541067:455541074(7) ack 3776373837 win 8192
99: 10:45:29.483114 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455541074:455541436(362) ack 3776373837 win 8192
100: 10:45:30.261201 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455541436:455541617(181) ack 3776373837 win 8192
101: 10:45:30.467505 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455541617:455541979(362) ack 3776373837 win 8192
102: 10:45:30.833437 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809435524:2809436784(1260) ack 1108453567 win 8192
103: 10:45:30.833498 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809436784:2809438044(1260) ack 1108453567 win 8192
104: 10:45:30.834856 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809438044:2809439049(1005) ack 1108453567 win 8192
105: 10:45:30.949871 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455541979:455542176(197) ack 3776373837 win 8192
106: 10:45:31.123711 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455542176:455542538(362) ack 3776373837 win 8192
107: 10:45:31.342374 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455542538:455542719(181) ack 3776373837 win 8192
108: 10:45:31.754202 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455542719:455542900(181) ack 3776373837 win 8192
109: 10:45:31.889236 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455542900:455543081(181) ack 3776373837 win 8192
110: 10:45:32.217411 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455543081:455543262(181) ack 3776373837 win 8192
111: 10:45:32.436119 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455543262:455543608(346) ack 3776373837 win 8192
112: 10:45:32.764303 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455543608:455543789(181) ack 3776373837 win 8192
113: 10:45:33.243670 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455543789:455543970(181) ack 3776373837 win 8192
114: 10:45:33.650051 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455543970:455544151(181) ack 3776373837 win 8192
115: 10:45:33.857850 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455544151:455544332(181) ack 3776373837 win 8192
116: 10:45:34.371547 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455544332:455544513(181) ack 3776373837 win 8192
117: 10:45:34.404703 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455544513:455544694(181) ack 3776373837 win 8192
118: 10:45:34.673503 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455544694:455544875(181) ack 3776373837 win 8192
119: 10:45:34.951580 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455544875:455545237(362) ack 3776373837 win 8192
120: 10:45:35.279648 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455545237:455545961(724) ack 3776373837 win 8192
121: 10:45:35.596282 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455545961:455546142(181) ack 3776373837 win 8192
122: 10:45:35.630231 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455546142:455547402(1260) ack 3776373837 win 8192
123: 10:45:35.630903 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455547402:455548133(731) ack 3776373837 win 8192
124: 10:45:35.826510 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455548133:455549393(1260) ack 3776373837 win 8192
125: 10:45:35.865067 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455549393:455550653(1260) ack 3776373837 win 8192
126: 10:45:35.865769 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455550653:455550965(312) ack 3776373837 win 8192
127: 10:45:36.154655 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455550965:455551854(889) ack 3776373837 win 8192
128: 10:45:36.482702 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455551854:455552956(1102) ack 3776373837 win 8192
129: 10:45:37.445319 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455552956:455553137(181) ack 3776373837 win 8192
130: 10:45:38.282776 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455553137:455553302(165) ack 3776373837 win 8192
131: 10:45:38.560655 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455553302:455553467(165) ack 3776373837 win 8192
132: 10:45:39.367244 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455553467:455553664(197) ack 3776373837 win 8192
133: 10:45:39.608534 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455553664:455553861(197) ack 3776373837 win 8192
134: 10:45:39.874481 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455553861:455554026(165) ack 3776373837 win 8192
135: 10:45:40.091807 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455554026:455554223(197) ack 3776373837 win 8192
136: 10:45:40.833559 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809439049:2809440309(1260) ack 1108453567 win 8192
137: 10:45:40.833620 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809440309:2809441569(1260) ack 1108453567 win 8192
138: 10:45:40.834643 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809441569:2809442574(1005) ack 1108453567 win 8192
139: 10:45:41.183202 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455554223:455554372(149) ack 3776373837 win 8192
140: 10:45:41.404291 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455554372:455555261(889) ack 3776373837 win 8192
141: 10:45:41.724236 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455555261:455555458(197) ack 3776373837 win 8192
142: 10:45:41.951122 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455555458:455555820(362) ack 3776373837 win 8192
143: 10:45:42.169836 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455555820:455556001(181) ack 3776373837 win 8192
144: 10:45:42.388529 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455556001:455556379(378) ack 3776373837 win 8192
145: 10:45:42.732246 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455556379:455557087(708) ack 3776373837 win 8192
146: 10:45:42.935422 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455557087:455557284(197) ack 3776373837 win 8192
147: 10:45:43.154151 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455557284:455557465(181) ack 3776373837 win 8192
148: 10:45:43.482290 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455557465:455557992(527) ack 3776373837 win 8192
149: 10:45:43.810306 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455557992:455559062(1070) ack 3776373837 win 8192
150: 10:45:44.138420 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455559062:455559243(181) ack 3776373837 win 8192
151: 10:45:44.466513 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455559243:455559589(346) ack 3776373837 win 8192
152: 10:45:44.794667 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455559589:455559786(197) ack 3776373837 win 8192
153: 10:45:45.054913 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455559786:455559967(181) ack 3776373837 win 8192
154: 10:45:45.341458 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455559967:455560313(346) ack 3776373837 win 8192
155: 10:45:45.669627 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455560313:455560659(346) ack 3776373837 win 8192
156: 10:45:46.013350 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455560659:455561335(676) ack 3776373837 win 8192
157: 10:45:46.461157 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455561335:455561516(181) ack 3776373837 win 8192
158: 10:45:46.669551 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455561516:455561697(181) ack 3776373837 win 8192
159: 10:45:46.982004 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455561697:455561878(181) ack 3776373837 win 8192
160: 10:45:47.447532 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455561878:455562027(149) ack 3776373837 win 8192
161: 10:45:47.629194 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455562027:455563287(1260) ack 3776373837 win 8192
162: 10:45:47.630018 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455563287:455563512(225) ack 3776373837 win 8192
163: 10:45:47.747535 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455563512:455563693(181) ack 3776373837 win 8192
164: 10:45:47.966273 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455563693:455564598(905) ack 3776373837 win 8192
165: 10:45:48.185003 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455564598:455564944(346) ack 3776373837 win 8192
166: 10:45:48.766439 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455564944:455565125(181) ack 3776373837 win 8192
167: 10:45:48.950603 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455565125:455565652(527) ack 3776373837 win 8192
168: 10:45:49.169379 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455565652:455566014(362) ack 3776373837 win 8192
169: 10:45:49.454306 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455566014:455566195(181) ack 3776373837 win 8192
170: 10:45:49.716241 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455566195:455566376(181) ack 3776373837 win 8192
171: 10:45:50.044339 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455566376:455567265(889) ack 3776373837 win 8192
172: 10:45:50.796513 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455567265:455567446(181) ack 3776373837 win 8192
173: 10:45:50.833727 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809442574:2809443834(1260) ack 1108453567 win 8192
174: 10:45:50.833788 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809443834:2809445094(1260) ack 1108453567 win 8192
175: 10:45:50.835451 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4357: P 2809445094:2809446099(1005) ack 1108453567 win 8192
176: 10:45:51.652187 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455567446:455567627(181) ack 3776373837 win 8192
177: 10:45:52.239398 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455567627:455567808(181) ack 3776373837 win 8192
178: 10:45:52.578140 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455567808:455567957(149) ack 3776373837 win 8192
179: 10:45:52.887908 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4355: P 455567957:455568894(937) ack 3776373837 win 8192
180: 10:45:53.437690 802.1Q vlan#1 P0 10.10.2.254.443 > 10.10.2.125.4386: S 1934499216:1934499216(0) ack 2990701453 win 8192 10.10.2.125.4388: . ack 2458491757 win 7963
253 packets shown
0 packet captured
0 packet shown
Nagaraja Thanthry Tue, 08/03/2010 - 10:48
Most likely the server you are trying to access is using Active FTP. If you have a spare public IP address, could you please try the following:
on the firewall:
static (inside,outside) netmask 255.255.255.255
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
service-policy global_policy global
Once these commands are configured, then try to access the server and see if it works.
Alternatively, you can ask the remote server administrators if they are using active FTP or passive FTP.
Hope this helps.
NT
Magnus Mortensen Sat, 08/07/2010 - 22:21
Scott,
     I just took a second look at the .doc you provided at the start. The screen shot you posted shows a packet tracer attempt of a packet:
- coming in the outside interface
- coming from source 150.199.100.225 port 21
- destined to 204.13.92.99 on port 21
This traffic flow doesn't make too much sense as you would never see packets to *and* from port 21...
The implicit rule error you are seeing in the output is becuase you are testing a packet coming in destined to  204.13.92.99. A packet destined to  204.13.92.99 would never come *in" the outside interface since  204.13.92.99 is the FTP you are trying to get to on the internet. THe 'implicit rule' you are hitting is the firewall denying traffic from hairpinning on the outside interface (if a packet came 'in' the outside destined to  204.13.92.99, the firewall would have to bounce it right back out the outside interface toward you ISP wouldn't it... )
In order to get a valid packet tracer output please select the following options in the GUI:
Interface: INSIDE
Source IP: (the IP address of the machine your are FTP'ing *from* (get this from 'ipconfig' on the machine)
Source Port: 12345
Destination IP:  204.13.92.99
Destination Port: 21
Or you can get this from the CLI with the following:
packet input inside tcp 12345  204.13.92.99 21 detailed
- Magnus
