How can I discover the serial number of the LMS application?
Answered Question
Aug 3rd, 2010
Hi - We are looking to get a support contract from Cisco for an LMS install for one of our customers.
Is there any way of finding out the serial number of the LMS software itself from the application?
Many Thanks, Dom
Correct Answer by Joe Clarke about 6 years 5 months ago
They are for Software and Support, so you get both upgrades and support.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 08/03/2010 - 10:45
LMS does not have a serial number.  Instead, it comes with a PAK ID that you use to obtain a license file.  I thought it was sufficient just to purchase an SAS contract for LMS (orderable IDs are like CON-SAS-LMS... depending on the license type of LMS).  For example, the part number of LMS 3.2 for a 5K device license is CON-SAS-LMS3X5K.
d-fillmore Tue, 08/03/2010 - 10:55
Thanks for your reply Joseph,
My customer has upgraded from version 2.6 to 3.2
The Server previously ran at 3.5GB of Memory, but following the upgrade now runs at over 5GB of Memory and is very slow and unresponsive
The Server is a HP Proliant DL380 G4.
I wanted to raise a TAC case, I thought the SAS contracts were more for software upgrades than tech support.
Cheers, Dom
Correct Answer
Joe Clarke Tue, 08/03/2010 - 11:00
d-fillmore Tue, 08/03/2010 - 11:24
Thanks Joseph,
I think I'll post the problem on here and see if anyone can give me any tips - As far as I know we only get shared support contracts, which I don't think we can do for SAS
Cheers, Dom
