Nexus 1000v VSM/VEM requirements
Aug 3rd, 2010
Hello to all,
We want to test in our labo a Nexus1000V solution based on two ESXi standalone nodes with a VEM installed on each one. On the same nodes we would like to install in a redundant way the VSM, it's not yet the final infrastructure since another possibility is to use a dedicated ESXi node for the VSM
My questions are the following:
  • Does the VSM support only 64bit VM??? There are no chance to install it on a 32 bit VM only for testing purposes
  • Same question as the one before but regarding the VEM...
  • which is the best solution having the VMS on the same node as the VEM or on a complete separate node?
Thanks for a feedback
Overall Rating: 4 (1 ratings)
Jason Aarons Fri, 08/06/2010 - 17:26
  • Bronze, 100 points or more
Correct ESX/ESXi is only 64-bit, you'll need 64-bit servers.  To be specific the VSM requires 64-bit as the VSM application is 64-bit.
Related Content
