Replacing a failed controller
Aug 3rd, 2010
Could anyone advise me on the easiest way of replacing a failed controller with a new one.
Should include easiest method of pushing config to controller from WCS etc.
Lee
Jeffrey Keown Tue, 08/10/2010 - 12:14
  • Cisco Employee,
Hi Lee,
If you're replacing it with the same type of controller, you can upload the config via the controller's gui (if it's still useable).
commands -> upload file -> config
Once you have ip connectivity to the new one, do the reverse of the process to apply the config
