New switch IOS/Config upgrade issues
Aug 3rd, 2010
This is a very basic question.
I have configured a 3560, vlan 1 with an IP address of 10.10.10.1, set fa0/1 to access vlan 1
I have set my laptop up with IP address 10.10.10.10, default gateway 10.10.10.1.
From the laptop I can PING and Telnet into the switch, however, from the switch I cannot PING or open up a TFTP session with the TFP server running on the laptop
I configured fa0/1 as:
switchport
switchport mode access
switchport access vlan 1
no shut
However, if I do a show run, there is only one line listed:
Interface Fa0/1
Overall Rating: 5 (1 ratings)
Jayakrishna Mada Tue, 08/03/2010 - 10:06
  • Cisco Employee,
The switchports are by default in vlan 1, so the command "switchport access vlan 1" is/was already in there, hence you don't see the command when you do a show run on the interface.
Check the firewall on the PC. I am pretty sure its the Windows firewall or other firewall blocking it. Disable that and it should start working.
JayaKrishna
